Electronics
Electronics
Applying IBIS in SIWizard
    • jason.traud
      I believe I'm appling the IBIS component models incorrectly.
      I copy and pasted the models into the directory below.
      C:Program FilesAnsysEMv231Win64buflibIBIS
      After launching the software I can now see the model in SIWizard, it allows me to select it and update.
      After the simulation runs, I get this warning for all of the nets. (I replaced the part number and pin with "..." due to length)
      Warning: Could not assign IBIS model "(NULL)" to ... (model not found)
      Do I need to do anything additional, other than copy and paste the IBIS into the folder and select it in the wizard?
      I imported the board into SIWave using IPC2581 if it matters.
Viewing 0 reply threads
