TAGGED: ansys-mechanical, ansys-workbench, apdl, static-structural
April 28, 2022 at 6:22 pm
josephngc
SubscriberI have a project I'm working on that has about 400 pressure points along a surface that are dependent on axial location. I have bolt pretensions and other loads induced on the part prior to when the pressure needs to be applied.
I have got this to work but with a fair bit of workaround. I'm seeking a sleeker solution. I found this discussion which uses the solution I found for plotting the pressures along the axis, and it works great. It is exactly what I want, aside from not being able to change which load step the pressure is applied in.
This is the discussion using the solution I implemented:
My solution for the time issue is I opened the .dat file for my part and located the table setup created by the table I created in the pressure object. The table has "TIME" defined in the *DIM command and it is defaulted to time 0-1, as shown below:
May 4, 2022 at 2:32 pmChandra Sekaran
Ansys EmployeeI may not fully follow you but looks like all you have to do is increase the number of time points. Currently you have "*dim,loadvzalue,tabe,10,2,1,z,time" which says you have 10 values for Z coordinate but only 2 values for TIME. You do not mention how many load steps you have and what the end times are for the load steps. By default, load step 1 ends at time=1 , load step 2 ends at time=2 etc. So if you have 5 load steps then you can change to "*dim,loadvalue,10,5,1,z,time" then define the pressure value vs Z at each time point. If, for example, the first two load steps are for bolt pretensioning without any pressure you just can put in zero values for the first two columns.
Viewing 1 reply thread- The topic ‘Apply pressure dependent on axial location and load step’ is closed to new replies.
6765
1330
1097
