Materials
Materials
Topics related to Granta Design and more.
apply a generell stiffness matrix in Ansys
    • Fred2233
      Hello everyone,I am tryind to modell a corrugated shell (steel) as an orthotropic shell with same thickness. I have found the eqiuvalent Youngs Module Ex Ey Ez etc to achieve an equivalent flexural stiffness and Ex',Ey',Ez to achieve an equivalent extensional stiffness for the orthotropic shell. But in Ansys I can only put one Ex and one Ey etc to modell the orthotropic elasticity.That means that I cannot model the shell with the same flexural and extensional stiffness as the corrugated shell at the same time. To achieve this I was thinking that a way would be to apply the stiffness matrix by yourself. I found in Internet that for Abaqus is possible. Can I do this in Ansys, because I am working with Ansys right now? Any help would be appreciated n
    • Chandra Sekaran
      Equation 2-4 in the ANSYS theory manual ( https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/ans_thry/thy_str1.html?q=orthotropic ) shows the stress-strain relationship used by orthotropic material. I guess you have a case where there are separate contributions that you want to add up. You can put in your own stiffness matrix using Matrix27 element discussed in the Elements manual ( https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/ans_elem/Hlp_E_MATRIX27.html )nn
  • The topic ‘apply a generell stiffness matrix in Ansys’ is closed to new replies.
