February 7, 2023 at 11:33 am
Pratik Ganorkar
SubscriberHi,Â
Can anyone please explain how to use UMAT for material erosion and coding for erosion appication? and How to plot Fringe Plotting of history variable (HSV) ?.
Pratik Ganorkar (pratik2116303@iitgoa.ac.in)
MTech Mecahnical EngineeringÂ
Indian Institute of Technology Goa (2021-2023)
February 8, 2023 at 8:57 pm
Andreas Koutras
Ansys EmployeeHello, Appendix A has an example umat41 subroutine showing how to consider material failure and subsequent element erosion. To fringe plot history variables, you will first need to have *DATABASE_EXTENT_BINARY included in the input and have the number of history variables to be extracted specified through NEIPH, NEIPS, BEAMIP for solid, shell, or beam elements respectively. Then, once you open d3plot in LSPP, go to Fringe Component > Misc and select a history variable to fringe. I hope this helps. -
February 22, 2023 at 9:46 am
Pratik Ganorkar
SubscriberHi Andreas,Â
Thank you very much for the response. I have learnt a lot from your advice.
The material erosion criteria I have been using is by UMAT. But it starts to give negative volume error, after adding CONTACT_EROSION_SURFACE_TO_SURFACE for all contact surface and taking high principle stress values in MAT_EROSION the entire plate gets deleted. What is the contact which I need to use to solve the problem.Â
The following image is of the elements gets deleted.
Thanking you
MTech Mechanical EngineeringÂ
- The topic ‘Application of UMAT’ is closed to new replies.
