Ansys Products
Ansys Products
Application failed to connect??
    • ngocvo254
      I am currently using Ansys 2020 R2 Student and when I create a Fluid Flow (Fluent) and try to result setup I get this error.
    • ANSYS_MMadore
      ArrayCan you please open a command prompt and send the full output of the set command?Thank you,nMattn
    • ngocvo254
      n
    • ANSYS_MMadore
      Array Are you able to run CFX Pre or CFD Post outside of workbench? Or do you encounter errors with that as well?nCan you try: Close Workbench and then delete the .cfx directory in C:\Usersgoct\ and the directory v202 in C:\Usersgoct\AppData\Local\Ansys and C:\Usersgoct\AppData\Roaming\Ansys.nThese directories contain temporary files and settings that are used during restarting Workbench or CFX and will be automatically regenerated with the default values.n
  • The topic ‘Application failed to connect??’ is closed to new replies.
