APDL command PRNSOL
    • maja.wolkenstein
      Hi!
      I am using following APDL command to print stresses in a text file:
      /OUTPUT,Shaft,txt,,APPEND  ! switch output to file 'Shaft.txt'
      PRNSOL,S,COMP            ! print all stress components
      /OUTPUT
      With the above command the x,y,z,xy,xz,yz the component stresses are ploted in the text file.
      With the following comand the principal stresses are printed in the txt file.
      PRNSOL,S,PRIN            ! print all stress components
      However I would like to print both component and principal stresses to a file. The result should look like this (see picture below).
      How can I combine PRNSOL,S,PRIN and PRNSOL,S,COMP that all stresses are written to the file (using both commands sequentially is not the desired solution)
      Thanks
      Wolke
    • Akshay Maniyar
      It looks like you have a duplicate post for the same query. To avoid confusion, I will close this query and you can continue at the below link.
      APDL command PRNSOL (ansys.com)
      Thanks,
      Akshay Maniyar
