January 15, 2025 at 5:18 pm
christof.schreijaeck
SubscriberHey there,
ich need Help. Every time i want to start the solver on my explicit dynamics project, a problem with the AnsysWBU.exe appears and it crashes.
I already tried several different versions of Ansys with the same result. Also clearing the %Temp%-Folder and new installations didn't helped.
Unfortunatly I'm not able to get any Information out of the Dump-File by myself. I'm totally lost and don't know what the problem could be.
I have no problems with the static-mechanic-solver.
I would appreciate any kind of help a lot. Ansys v24.2 Student
January 16, 2025 at 2:30 pm
Chris Quan
Ansys EmployeeIn Explicit Dynamics system GUI, can you right click on Solution in Tree and then click on Open Data File Directory? Are there any files in this folder? If yes, can you take a look at them to see if they give you more information about the problem?
Furthermore, before click on Solve, can you uncheck the button "Distributed" on the top tool bar to turn off distributed solution?
You mentioned that the problem has been present in several versions of ANSYS. Which platform are you using, Windows or Linux? If you are using Linux, can you try it in a Windows machine?
2858
970
851
599
591
