November 8, 2021 at 5:19 pm
elad123
SubscriberHi,
I installed ANSYS student and when I try to open Ansys Workbench I get the following error massage:
An unexpected error has occurred: The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit.
--- System.AggregateException: The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit.
--- System.Exception: SceneGraph.Engine - failed to boot up.
  at Ans.SceneGraphChart.Engine..ctor(IConfiguration p_config, IErrorHandler p_errorHandler)
  at Ans.SceneGraphChart.SceneGraphAddin.Load(AddinLoadContext context)
  at Ansys.Core.Addins.AddinManager.setupAddin(String path, String name, AddinBase addin)
  at Ansys.Core.Addins.AddinManager.LoadAddin(String name, String path)
From reading old posts in this forum I understand that creating a new local account (with username in English) on my computer may solve the problem. Is there any other solution?
Thanks,
Elad
November 9, 2021 at 8:49 pmGeorge Karnos
Ansys EmployeeThat is one solution.
Please check the other posts for other ideas:
/forum/search?Search=Ans.SceneGraphChart.SceneGraphAddin&ADV_Filter_SearchIn=&ADV_Filter_Category=&ADV_Filter_QNA=&ADV_Filter_CommentCount=&ADV_Filter_Username=&ADV_Filter_SearchOccurrence=any_occurrence
September 24, 2022 at 4:24 amDohyun Kim
SubscriberI met this error changing my windows utf-8 preferences, so you may try:
1. Open the Windows Control Panel
2. Select [Clock and Region]-[Region]
3. Open the [Administration] Tab
4. """UnCheck""" "Beta: Use Unicode UTF-8 in worldwide languages" from "Change system locale".
5. Restart Windows.August 9, 2023 at 8:57 amls ls
SubscriberDohyun Kim Subscriber,thank you very much,your method is useful
Viewing 3 reply threads- The topic ‘Ansys WorkBench Unexpected Error’ is closed to new replies.
5819
