Ansys Workbench Project view shows “Solved” but mechanical shows “Solve Required”. How to fix this ?
TAGGED: ansys-mechanical, ansys-workbench, hpc, linux-cluster
October 15, 2020 at 8:17 am
GeoStrike
SubscriberOctober 15, 2020 at 8:37 amOctober 16, 2020 at 12:30 pmGeoStrike
SubscriberThanks for the idea Array. nI had in the meanwhile let the whole project run again. nInstead of clicking on the Update Project, i clicked on Solve in Ansys Mechanical. Worked without any problems.But i will try and replicate the issue and try your solution.Thanks a lot. nAllennNovember 16, 2020 at 9:00 amGeoStrike
SubscriberThanks again for the idea .nI had this problem again today morning. and tried your method. Worked very well. nBest Regards nAllen nViewing 3 reply threads- The topic ‘Ansys Workbench Project view shows “Solved” but mechanical shows “Solve Required”. How to fix this ?’ is closed to new replies.
Innovation SpaceTrending discussions- LPBF Simulation of dissimilar materials in ANSYS mechanical (Thermal Transient)
- APDL, memory, solid
- Meaning of the error
- Contact stiffness too big
Top Contributors-
4167
1487
1338
1188
