TAGGED: ansys-workbench, command-line, free-surface, pipe-analyses, pipe289
March 12, 2021 at 8:39 am
BD1995
SubscriberHello, I'm using Ansys workbench and I don't know how to apply commands for pipe elements. I have a pipeline model shown in the figure below.
March 19, 2021 at 1:52 pmdlooman
Ansys EmployeeIt's confusing to have to specify a free surface when the piping system is closed and all you want is to include the weight of the internal fluid. It's required though (to compute hydrostatic pressure), so if the largest z coordinate of your nodes is 10.0, the command you started would be: SFE,ALL,3,PRES,,10.1. Since you specified MINT=3 in your SECDATA command you need to have a material property 3 defined with a command like MP,DENS,3,9.34e-5 ! water in lb-in system. nMarch 23, 2021 at 10:56 amBD1995
SubscriberThank you so much for help. it's a bit confusing, but this will solve the problem! nViewing 2 reply threads- The topic ‘Ansys Workbench PIPE 288/289 internal fluid weight’ is closed to new replies.
5849
