March 27, 2019 at 8:09 pm
mijungry
SubscriberI am currently running ANSYS Workbench 19.1 using Windows 10 on a boot camp Mac partition. Up until today ANSYS was working perfectly fine, but now when I try to open it up the logo for Workbench opens up for a brief moment and then a message pops up saying that "ANSYS Workbench has stopped working". I tried uninstalling and reinstalling the software but nothing has worked. Any help would be much appreciated. I have also tried running it as an administrator but the same thing keeps happening.Â
If I try to open a specific project this error pops up.Â
March 28, 2019 at 1:07 am
tsiriaks
Ansys EmployeeOpen up CMD Prompt, then issue the following command
move %appdata%ansys %appdata%ansys.old
Does this help ?
If not, in the CMD Prompt , issue this command
set
and post the output of it.
Also, make sure all pending Windows updates are installed.
Thanks,
Win
April 17, 2019 at 2:16 pm
April 17, 2019 at 2:21 pm
mijungry
SubscriberSpaceclaim still opens up but ANSYS Workbench will not open up.
April 17, 2019 at 2:57 pm
JakeC
Ansys EmployeeHi mijungry,
Please try the following from a command prompt:
set PATH=C:windows;C:windowsSystem32Wbem;C:windowssystem32;
press enter
then type:
"c:program filesansys incv193FrameworkbinWin64"runwb2
Press enter.
See if that launches workbench.
Thank you,
Jake
April 17, 2019 at 3:01 pm
mijungry
SubscriberIt gave the same error as previously mentioned where the logo for Workbench opens up for a brief moment and then a message pops up saying that "ANSYS Workbench has stopped working".
April 17, 2019 at 3:06 pm
JakeC
Ansys EmployeeDoes this happen for all projects, or just this one?
Thank you,
Jake
April 17, 2019 at 3:08 pm
mijungry
SubscriberIt happens for all projects that are workbench files but Space Claim files will still open up.Â
April 17, 2019 at 4:12 pm
JakeC
Ansys EmployeeThe error message does look like a corrupted appdata setting as Win suggested earlier.
When you renamed the %APPDATA%ansys directory was all of the ansys applications close?
Can you try that again, and verify that the path looks like:
C:Users
AppDataRoamingAnsys
As you stated earlier it is possible that this is a corrupted install.
Please rename the c:program filesansys incv191 directory and do the reinstall then.
After that look at the c:program filesansys incinstall.log file and install.err files for errors during the install.
Thank you,
Jake
April 17, 2019 at 4:53 pm
mijungry
SubscriberHi Jake,Â
When I try to the move appdataansys appdataansys.old commandÂ
I receive this output after trying to reinstall the software for the 4th time of:Â
C:UsersMartin Mija>move appdataansys appdataansys.old
The system cannot find the file specified.
ANSYS applications are not opened during this time, and I ran the install as an administrator and deleted all of the previous ANSYS files on my computer.Â
Best,
MartinÂ
April 17, 2019 at 4:57 pm
April 17, 2019 at 5:03 pm
mijungry
SubscriberAlso if I try to reinstall it again do you have tips on what I should do while I uninstall the program to ensure that the next install will be succesdul?
Best,
MartinÂ
JakeC
Ansys EmployeeHi Martin,
Please close all ansys applications.
Open the windows file explorer.
In the Path/Address bar type in:
%APPDATA%
Press enter
Rename the Ansys directory to Ansys_old
Then restart the ansys applications.
Thank you,
Jake
- The topic ‘ANSYS Workbench 19.1 Will Not Open’ is closed to new replies.
3892
1414
1241
1118
1015
