November 25, 2023 at 5:22 pm
ANSYS EXPLORER
SubscriberDear Experts, Requesting your guidance to fix this error while running subject FE model.
Errors as below:
 *** ERROR ***                          CP =    683.672  TIME= 22:43:19
 The program is unable to open file file.DSPtri. If the suggestions inÂ
 the associated error messages immediately preceding and/or following  Â
 this error message do not help resolve the file issue, please send theÂ
 data leading to this operation to your technical support provider,    Â
 along with the I/O error code of 999 and the system error code of 0,  Â
 for help in determining the possible reasons as to why this file couldÂ
 not be opened.ÂÂ
 The program is unable to open file file.DSPtri. Unit 90 is already inÂ
 use. Please send the data leading to this operation to your technicalÂ
 support provider, as this will allow ANSYS, Inc to improve the        Â
 program.Â
Regrads
AE
November 27, 2023 at 1:10 pm
Aniket Chavan
Forum ModeratorANSYS WORK BENCH – THERMAL STEADY STATE + STRUCTRUAL ANLYSIS Is this the same question?
-Aniket
November 27, 2023 at 3:17 pm
mrife
Ansys EmployeeHi Ansys Explorer
Is the Workbench Project saved to a folder on your MS OneDrive? If so save it to some other location; OneDrive can have security scanning and backup of files. Which can impede other programs access to the file. Alternatively there could be some other security or backup application doing the same.
How much free space is on the storage drive? It's also possible that the storage drive is running out of space.
Mike
November 28, 2023 at 12:13 pm
ANSYS EXPLORER
SubscriberDear Mike / Aniket ,
Thank you for your swift response.
To Mike : I am working in VDI machine having (128GB RAM + 4 Cores + 100GB additonal storage) remotely. While running model, the solution getting stopped even at 4% growth during structural analysis when free memory space around 80GB avaiable in machine. Please advise on path-forward.
To Aniket: I have raised questions in this forum per error wise though it is pertaining to same FE model. The error is different in the below question.
Thank you.
Regards
AE
- The topic ‘ANSYS WORK BENCH ERROR WHILE RUNNING THERMAL STEADY STATE + STATIC STRUCTUAL’ is closed to new replies.
6600
1311
