December 9, 2023 at 10:58 pm
December 11, 2023 at 9:19 am
Sampat Kumar
Ansys EmployeeHi Muhammad,
These two messages are warnings that you can safely ignore if they don't impact your results. However, I've explained the potential causes below just in case.
The first warning indicates that the solution's converged value is significantly smaller than the established threshold. This can occur when the applied load is very small or completely absent. If your model converges smoothly and appears stable, you can probably ignore this warning. However, if you're having convergence issues, this warning may be a indication of the problem
For overwriting the minimum reference value in the Ansys there are the following available options.
1. Go to Non-Linear Controls in the Analysis setting and check the temperature convergence.
2. Go through the CNVTOL and MINREF commands for more details to overwrite the convergence value.
Second warning- Go through the following forum thread for more details.
/forum/forums/topic/error-during-transient-thermal-and-static-structural-analysis/
/forum/forums/topic/error-during-static-structural-analysis/
Sampat
- The topic ‘Ansys Static Structural Analysis Warnings’ is closed to new replies.
6465
