Optics
Optics
Topics related to Speos.
Ansys Speos regulatory compliance
    • Yin Zhang
      您好,我目前正在使用Ansys Speos进行法律和法规合规性验证,但我不确定如何在Speos中执行特定操作。例如,我获得了一些模拟结果,但我无法将这些结果与现有法规进行比较。你能指导我如何进行这样的比较吗?"Could you please do a case demonstration? Thank you."
      "Hi, I'm working on validating lighting designs against legal and regulatory standards within Ansys Speos, however, I am unclear about the process of comparing my simulation outcomes directly with the prevailing regulations. Can you advise on how to properly compare the simulation results with the requirements stipulated by the relevant standards within the software?"
    • nomad
      Hi Yin,
      Please check Regulations in Virtual Photometric Lab (ansys.com) It includes a workflow.
      You can also contact your local support if you need more detailed information/help.
    • Yin Zhang
      Hello, could you please tell me how to download an "XML" file and where can I find it for download?
      • nomad
        It's in the wokrflow, "Regulations are included in the Optics Library that you can download on the Ansys Portal.", optical libraries under add-on packages on Ansys Portal.
  • The topic ‘Ansys Speos regulatory compliance’ is closed to new replies.
