April 20, 2020 at 10:08 am
PMwanza
SubscriberI've currently using ANSYS Academic version 2020 R1 . I have been trying to simulate a 3 blade VAWTÂ (Shown) in Fluent after creation of the geometry in space Claim but upon attempting to apply an enclosure before meshing I keep getting the following error.
" An error occurred while creating the enclosure - 2 bodies could not be subtracted from the enclosure body"
Kindly assist , what needs to be done. -
April 20, 2020 at 10:39 am
Forum ModeratorIs the enclosure bigger than the blade? If a surface is touching are the two surfaces identical? For the latter it may be easier to extrude the blade slightly so it's sticking out of the enclosure.Â
April 20, 2020 at 11:51 am
PMwanza
SubscriberYes the enclosure is 5 times bigger than the whole rotor comprising of the 3 blades and no surface surface is touching
April 21, 2020 at 5:43 am
Keyur Kanade
Ansys Employeeselect bodies in structure tree --> right click --> select check geometry.Â
your geometry must be error free before you use combine.Â
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
April 22, 2020 at 12:11 pm
PMwanza
SubscriberI have check the geometry and its coming out with no issue but upon using combine tool the error I am getting is as below;
Cannot merge bodies (operation failed because faces and edges would combine in a way that does not form a valid solid or surface)
April 22, 2020 at 4:11 pm
Forum ModeratorIn which case, are there any thin bodies in the cutting piece?
April 22, 2020 at 6:12 pm
PMwanza
SubscriberYes there is
April 27, 2020 at 12:35 pm
PMwanza
SubscriberThe problem is still unresolved. Any suggestions please
April 28, 2020 at 10:41 am
Forum ModeratorThe first suggestion is not to post extra threads: they take time to clean up.
If there are thin bodies enclosure may struggle. Have a look at Fluent Meshing as I think you can put a shell around the object (same size & shape as your enclosure) and see how baffles are handled.Â
May 14, 2021 at 11:52 am
manelaero2020
Subscriber.Hi
the problem is : Your surface is thin
solution :
1/ you can pull it ( pull function ) if your surface is not complicated
2/ you can use the stitch function
please look at the following video
3/ I don't know a lot about this function but you can try: facets then: thicken
Stitch function is enough to solve the problem
- The topic ‘ANSYS SpaceClaim enclosure subtraction failure/error’ is closed to new replies.
6535
1311
