Electronics
Electronics
Ansys Q3D import
    • Andrew
      I want to extract inductances of bus bars designed in solidworks.
      Can anyone let me know that if it is possible to import a mechanical design from solidworks to ansys Q3D?
      Like any specific file format which will do this trick?
      Thanks
    • Praneeth Munaga
      Hi Abdul,
      Thank you for reaching out to the Ansys learning forum.
      Yes, it is possible to import from SOLIDWORKS to Ansys Q3D. For detailed information, please go through "Importing 3D Model Files" section of the Q3D help document available under the Help menu in the tool interface.
      Best regards,
      Praneeth.
    • Andrew
      Thank you Praneeth!
  • The topic ‘Ansys Q3D import’ is closed to new replies.
