April 4, 2020 at 6:38 am
Pranavpadvil
SubscriberI am doing periodic flow and heat transfer problem at constant wall temperature. so how to evaluate the Nu value from periodic heat transfer case? temp. drop in periodic section whether gives correct Nu value or not?
April 6, 2020 at 1:48 pm
RK
Ansys EmployeeHello,Â
There are many ways. One way is you can view it is in the contours section by selecting wall fluxes and under the wall fluxes drop down menu, you can select Nu number.Â
RahulÂ
- The topic ‘ansys periodic heat transfer’ is closed to new replies.
1306
