April 8, 2025 at 2:41 am
ljcish26
SubscriberI want to use DOE to find a combination of design variables (Damping coefficient, Offset, Stiffness coefficient) that maintains the stability (convergence) of the model and a constant amplitude.
I created a marker on the axis and created a function expression and set it to PI.However, when I run DOE, the following error occurs.
ANSYS MOTION 2024 R1   24.10.31023 (build.fc843c69)    Mon Apr  7 04:09:13 2025 PM*** ERROR ***                       Mon Apr  7 04:09:15 2025 PM
AN ERROR OCCURRED WHILE CALLING FUNCTION EXPRESSION (MOTION ERROR)*
exception: access violation reading 0x0000000000000008 * FUNCTION EXPRESSION ID Â = 1
* FUNCTION EXPRESSION NAME = /Unb_Nor_250402/FN_002
* FUNCTION EXPRESSION Â Â Â = SQRT(AX("/Pump_shaft/MK_pump_coup", "/Pump_shaft/CM")^2 + AY("/Pump_shaft/MK_pump_coup", "/Pump_shaft/CM")^2)
* SIMULATION TIME = 0.00000000e+00
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------An error occurs when loading the function expression, but the kinematic request of the marker is set as shown in the picture below.
I want to know which part is the problem.
I use ANSYS motion(Standalone) 24R1. -
April 14, 2025 at 3:13 pm
dev.sarkar
SubscriberIt seems you have a syntax error. The AX and AY terms need to be in a separate bracke,t and that can be squared.Â
6455
