July 20, 2023 at 10:46 am
Marcelo Precoppe
SubscriberI have updated to 2023 R2 and I am receiving the following error when I open the Ansys Motion Simulation results:
- I indeed have an academic license, but this issue does not occur on the 2023 R1
- Indeed the simulation contains more than 50 bodies (it is the simulation of a belt on a pulley, thus each segment of the belt counts as a body)
- The simulation completes correctly, the issue is only opening the ANSYS Motion Postprocessor 2023Â R2
Could that be a bug, considering this limitation was not present on 2023 R1 or earlier versions?
Kind regards,
Marcelo -
July 20, 2023 at 1:14 pm
Nanda
Ansys EmployeeHello Marcelo,
The documentation clearly mentions that more than 50 bodies are not supported. I'm not sure how you were able to open in previous versions. Is it the same model you're opening?
Kindly refer to "Problem size limits" section below:
Download Ansys Student | Workbench-based Simulation Tools
Nanda.
If you are not able to open the links, refer to this forum discussion:Â How to access the ANSYS Online Help
For more exciting courses and certifications, hit this link: Ansys Innovation Courses | Ansys Innovation Space
July 20, 2023 at 1:49 pm
Marcelo Precoppe
SubscriberDear Nanda,
Thanks for the prompt reply. The 50 bodies limitation is indeed explicit for free Student Licenses. However, I have a paid Academic License and I cannot find where such limitation is stated for paid Academic License. Can you help me with that?
Kind regards,Marcelo
July 25, 2023 at 8:08 am
Marcelo Precoppe
SubscriberFollowing up on this issue, I have clarified that my license is not the free student one, where the 50 bodies limitations apply. My license is the paid academic license where the 50 bodies' limitations do not apply. Can you help me with this error message?
July 25, 2023 at 11:41 am
George Karnos
Ansys EmployeeIf you open Client License Settings 2023 R2 and choose:
Fatures in useWhat licenses does it list?
Also, if you browse to:
%TEMP%\.ansys
You will see .out files for the programs run. These are client licensing debug files.
Open the .out file for what you are running and post what license it is checking out.
(Do not attach files as we are not permitted to open files)
Please post contents of the files. -
July 25, 2023 at 12:14 pm
George Karnos
Ansys EmployeeOn the license server, can you check the license file and post the increment line for vmotion_post
example:
INCREMENT vmotion_post ansyslmd 9999.9999 29-mar-2024 10 9BB7F8AF6D98 \
  VENDOR_STRING=customer:00000000 SUPERSEDE \
  ISSUER=ANSYS_SSL ISSUED=29-mar-2023 BORROW=720 \
  START=29-mar-2023 SIGN="00A3 B99E F516 CE83 E8A3 2FF4 3883 \
  DE00 36D4 FA0E 6CC9 8B17 4D92 628F 9699" SIGN2="0064 4172 2F34 \
  790D C1E8 5000 4501 D100 7494 1D5C 8B1B 5D76 0A30 A15A 8FFA" -
July 25, 2023 at 12:15 pm
Marcelo Precoppe
SubscriberIn addition, if I browse to "%TEMP%\.ansys" there are 2 ".out" files related to Ansys Motion 2023 R2 (Computer name has been replaced with "_____"):
1. licdebug._______.VMOTION.232.out
2. licdebug.________.FEAT_VMOTION.232.out
See the content of those files below (with sensitive data replaced with _____)
2023/07/18 13:13:47 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 6/6/7/7 Â 9376:VMOTION:_______@___________________________winx64 Â 7836:172.23.240.1 Â Â
2023/07/18 13:13:47 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 53213@127.0.0.1.
2023/07/18 13:13:47   CHECKOUT       vmotion             23.2 (2023.0505)       1/1/1/1         6/6/7/7  9376:VMOTION:_______@___________________________winx64  7836:172.23.240.1  Â
2023/07/18 13:13:47 Â Â CHECKOUT Â Â Â Â Â Â vmotion (Share) Â Â Â Â Â Â Â Â 23.2 (2023.0505) Â Â Â Â Â Â 1/-/-/- Â Â Â Â Â Â Â Â 6/6/7/7 Â 9376:VMOTION:_______@___________________________winx64 Â 7836:172.23.240.1 Â Â
2023/07/18 13:45:48 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 9/9/11/11 Â 21992:VMOTION:_______@___________________________winx64 Â 7960:172.23.240.1 Â Â
2023/07/18 13:45:48 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 53213@127.0.0.1.
2023/07/18 13:45:48   CHECKOUT       vmotion             23.2 (2023.0505)       1/2/2/2        9/9/11/11  21992:VMOTION:_______@___________________________winx64  7960:172.23.240.1  Â
2023/07/18 13:45:48 Â Â CHECKOUT Â Â Â Â Â Â vmotion (Share) Â Â Â Â Â Â Â Â 23.2 (2023.0505) Â Â Â Â Â Â 1/-/-/- Â Â Â Â Â Â Â 9/9/11/11 Â 21992:VMOTION:_______@___________________________winx64 Â 7960:172.23.240.1 Â Â
2023/07/18 14:44:33 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 6/6/7/7 Â 5184:VMOTION:_______@___________________________winx64 Â 7872:172.23.240.1 Â Â
2023/07/18 14:44:33 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 54277@127.0.0.1.
2023/07/18 14:44:33   CHECKOUT       vmotion             23.2 (2023.0505)       1/1/1/1         6/6/7/7  5184:VMOTION:_______@___________________________winx64  7872:172.23.240.1  Â
2023/07/18 14:44:33 Â Â CHECKOUT Â Â Â Â Â Â vmotion (Share) Â Â Â Â Â Â Â Â 23.2 (2023.0505) Â Â Â Â Â Â 1/-/-/- Â Â Â Â Â Â Â Â 6/6/7/7 Â 5184:VMOTION:_______@___________________________winx64 Â 7872:172.23.240.1 Â Â
2023/07/18 17:18:24 Â Â CHECKIN Â Â Â Â Â Â vmotion (Share) Â Â Â Â Â Â Â Â 23.2 (2023.0505) Â Â Â Â Â Â 1/-/-/- Â Â Â Â Â Â Â Â 6/6/7/7 Â 5184:VMOTION:_______@___________________________winx64 Â 7872:172.23.240.1 Â Â
2023/07/18 17:18:24   CHECKIN       vmotion             23.2 (2023.0505)       1/0/0/1         6/6/7/7  5184:VMOTION:_______@___________________________winx64  7872:172.23.240.1  Â
2023/07/18 17:18:24 Â Â CLIENT_EXIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 5/6/7/7 Â 5184:VMOTION:_______@___________________________winx64 Â 7872:172.23.240.1 Â Â
2023/07/18 17:20:56 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 6/6/8/8 Â 34368:VMOTION:_______@___________________________winx64 Â 7908:172.23.240.1 Â Â
2023/07/18 17:20:56 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 54277@127.0.0.1.
2023/07/18 17:20:57   CHECKOUT       vmotion             23.2 (2023.0505)       1/1/1/1         6/6/8/8  34368:VMOTION:_______@___________________________winx64  7908:172.23.240.1  Â
2023/07/18 17:20:57 Â Â CHECKOUT Â Â Â Â Â Â vmotion (Share) Â Â Â Â Â Â Â Â 23.2 (2023.0505) Â Â Â Â Â Â 1/-/-/- Â Â Â Â Â Â Â Â 6/6/8/8 Â 34368:VMOTION:_______@___________________________winx64 Â 7908:172.23.240.1 Â Â
2023/07/19 07:50:45 Â Â CHECKIN Â Â Â Â Â Â vmotion (Share) Â Â Â Â Â Â Â Â 23.2 (2023.0505) Â Â Â Â Â Â 1/-/-/- Â Â Â Â Â Â Â Â 6/6/8/8 Â 34368:VMOTION:_______@___________________________winx64 Â 7908:172.23.240.1 Â Â
2023/07/19 07:50:45   CHECKIN       vmotion             23.2 (2023.0505)       1/0/0/1         6/6/8/8  34368:VMOTION:_______@___________________________winx64  7908:172.23.240.1  Â
2023/07/19 07:50:45 Â Â CLIENT_EXIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 5/6/8/8 Â 34368:VMOTION:_______@___________________________winx64 Â 7908:172.23.240.1 Â Â
2023/07/19 08:02:58 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 6/6/13/13 Â 29524:VMOTION:_______@___________________________winx64 Â 7984:172.23.240.1 Â Â
2023/07/19 08:02:58 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 62640@127.0.0.1.
2023/07/19 08:02:58   CHECKOUT       vmotion             23.2 (2023.0505)       1/1/1/1        6/6/13/13  29524:VMOTION:_______@___________________________winx64  7984:172.23.240.1  Â
2023/07/19 08:02:58 Â Â CHECKOUT Â Â Â Â Â Â vmotion (Share) Â Â Â Â Â Â Â Â 23.2 (2023.0505) Â Â Â Â Â Â 1/-/-/- Â Â Â Â Â Â Â 6/6/13/13 Â 29524:VMOTION:_______@___________________________winx64 Â 7984:172.23.240.1 Â Â
2023/07/19 13:00:26 Â Â CHECKIN Â Â Â Â Â Â vmotion (Share) Â Â Â Â Â Â Â Â 23.2 (2023.0505) Â Â Â Â Â Â 1/-/-/- Â Â Â Â Â Â Â 6/6/13/13 Â 29524:VMOTION:_______@___________________________winx64 Â 7984:172.23.240.1 Â Â
2023/07/19 13:00:26   CHECKIN       vmotion             23.2 (2023.0505)       1/0/0/1        6/6/13/13  29524:VMOTION:_______@___________________________winx64  7984:172.23.240.1  Â
2023/07/19 13:00:26 Â Â CLIENT_EXIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 5/6/13/13 Â 29524:VMOTION:_______@___________________________winx64 Â 7984:172.23.240.1 Â Â
2023/07/19 16:15:08 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 6/6/7/7 Â 35688:VMOTION:_______@___________________________winx64 Â 7888:172.23.240.1 Â Â
2023/07/19 16:15:08 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 50558@127.0.0.1.
2023/07/19 16:15:08   CHECKOUT       vmotion             23.2 (2023.0505)       1/1/1/1         6/6/7/7  35688:VMOTION:_______@___________________________winx64  7888:172.23.240.1  Â
2023/07/19 16:15:08 Â Â CHECKOUT Â Â Â Â Â Â vmotion (Share) Â Â Â Â Â Â Â Â 23.2 (2023.0505) Â Â Â Â Â Â 1/-/-/- Â Â Â Â Â Â Â Â 6/6/7/7 Â 35688:VMOTION:_______@___________________________winx64 Â 7888:172.23.240.1 Â Â
2023/07/19 17:46:14 Â Â CHECKIN Â Â Â Â Â Â vmotion (Share) Â Â Â Â Â Â Â Â 23.2 (2023.0505) Â Â Â Â Â Â 1/-/-/- Â Â Â Â Â Â Â Â 6/6/7/7 Â 35688:VMOTION:_______@___________________________winx64 Â 7888:172.23.240.1 Â Â
2023/07/19 17:46:14   CHECKIN       vmotion             23.2 (2023.0505)       1/0/0/1         6/6/7/7  35688:VMOTION:_______@___________________________winx64  7888:172.23.240.1  Â
2023/07/19 17:46:14 Â Â CLIENT_EXIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 5/6/7/7 Â 35688:VMOTION:_______@___________________________winx64 Â 7888:172.23.240.1 Â Â
2023/07/19 19:58:48 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 6/6/9/9 Â 23380:VMOTION:_______@___________________________winx64 Â 7976:172.23.240.1 Â Â
2023/07/19 19:58:48 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 50558@127.0.0.1.
2023/07/19 19:58:48   CHECKOUT       vmotion             23.2 (2023.0505)       1/1/1/1         6/6/9/9  23380:VMOTION:_______@___________________________winx64  7976:172.23.240.1  Â
2023/07/19 19:58:48 Â Â CHECKOUT Â Â Â Â Â Â vmotion (Share) Â Â Â Â Â Â Â Â 23.2 (2023.0505) Â Â Â Â Â Â 1/-/-/- Â Â Â Â Â Â Â Â 6/6/9/9 Â 23380:VMOTION:_______@___________________________winx64 Â 7976:172.23.240.1 Â Â
2023/07/19 21:17:57 Â Â CHECKIN Â Â Â Â Â Â vmotion (Share) Â Â Â Â Â Â Â Â 23.2 (2023.0505) Â Â Â Â Â Â 1/-/-/- Â Â Â Â Â Â Â Â 6/6/9/9 Â 23380:VMOTION:_______@___________________________winx64 Â 7976:172.23.240.1 Â Â
2023/07/19 21:17:57   CHECKIN       vmotion             23.2 (2023.0505)       1/0/0/1         6/6/9/9  23380:VMOTION:_______@___________________________winx64  7976:172.23.240.1  Â
2023/07/19 21:17:57 Â Â CLIENT_EXIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 5/6/9/9 Â 23380:VMOTION:_______@___________________________winx64 Â 7976:172.23.240.1 Â Â
2023/07/22 09:53:04 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 7/7/34/34 Â 6412:VMOTION:_______@___________________________winx64 Â 8244:172.23.240.1 Â Â
2023/07/22 09:53:04 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 63606@127.0.0.1.
2023/07/22 09:53:05   CHECKOUT       vmotion             23.2 (2023.0505)       1/1/1/1        7/7/34/34  6412:VMOTION:_______@___________________________winx64  8244:172.23.240.1  Â
2023/07/22 09:53:05 Â Â CHECKOUT Â Â Â Â Â Â vmotion (Share) Â Â Â Â Â Â Â Â 23.2 (2023.0505) Â Â Â Â Â Â 1/-/-/- Â Â Â Â Â Â Â 7/7/34/34 Â 6412:VMOTION:_______@___________________________winx64 Â 8244:172.23.240.1 Â Â
2023/07/22 09:56:26 Â Â CHECKIN Â Â Â Â Â Â vmotion (Share) Â Â Â Â Â Â Â Â 23.2 (2023.0505) Â Â Â Â Â Â 1/-/-/- Â Â Â Â Â Â Â 7/7/34/34 Â 6412:VMOTION:_______@___________________________winx64 Â 8244:172.23.240.1 Â Â
2023/07/22 09:56:26   CHECKIN       vmotion             23.2 (2023.0505)       1/0/0/1        7/7/34/34  6412:VMOTION:_______@___________________________winx64  8244:172.23.240.1  Â
2023/07/22 09:56:26 Â Â CLIENT_EXIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 6/7/34/34 Â 6412:VMOTION:_______@___________________________winx64 Â 8244:172.23.240.1 Â Â
2023/07/19 19:51:25 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 6/6/8/8 Â 31316:FEAT_VMOTION:_______@___________________________:winx64 Â 7928:172.23.240.1 Â Â
2023/07/19 19:51:25 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 50558@127.0.0.1.
2023/07/19 19:51:25   CHECKOUT       vmotion_post           23.2 (2023.0505)       1/1/1/1         6/6/8/8  31316:FEAT_VMOTION:_______@___________________________:winx64  7928:172.23.240.1  Â
2023/07/19 19:51:25 Â Â CHECKOUT Â Â Â Â Â Â vmotion_post (Share) Â Â Â Â Â Â 23.2 (2023.0505) Â Â Â Â Â Â 1/-/-/- Â Â Â Â Â Â Â Â 6/6/8/8 Â 31316:FEAT_VMOTION:_______@___________________________:winx64 Â 7928:172.23.240.1 Â Â
2023/07/22 09:58:31 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 7/7/35/35 Â 22060:FEAT_VMOTION:_______@___________________________:winx64 Â 8340:172.23.240.1 Â Â
2023/07/22 09:58:31 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 63606@127.0.0.1.
2023/07/22 09:58:31   CHECKOUT       vmotion_post           23.2 (2023.0505)       1/1/1/1        7/7/35/35  22060:FEAT_VMOTION:_______@___________________________:winx64  8340:172.23.240.1  Â
2023/07/22 09:58:31 Â Â CHECKOUT Â Â Â Â Â Â vmotion_post (Share) Â Â Â Â Â Â 23.2 (2023.0505) Â Â Â Â Â Â 1/-/-/- Â Â Â Â Â Â Â 7/7/35/35 Â 22060:FEAT_VMOTION:_______@___________________________:winx64 Â 8340:172.23.240.1 Â Â
2023/07/24 13:36:15 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 6/6/7/7 Â 16852:FEAT_VMOTION:_______@___________________________:winx64 Â 7872:172.23.240.1 Â Â
2023/07/24 13:36:15 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 62292@127.0.0.1.
2023/07/24 13:36:15   CHECKOUT       vmotion_post           23.2 (2023.0505)       1/1/1/1         6/6/7/7  16852:FEAT_VMOTION:_______@___________________________:winx64  7872:172.23.240.1  Â
2023/07/24 13:36:15 Â Â CHECKOUT Â Â Â Â Â Â vmotion_post (Share) Â Â Â Â Â Â 23.2 (2023.0505) Â Â Â Â Â Â 1/-/-/- Â Â Â Â Â Â Â Â 6/6/7/7 Â 16852:FEAT_VMOTION:_______@___________________________:winx64 Â 7872:172.23.240.1 Â Â
2023/07/24 16:38:14 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 6/6/7/7 Â 32928:FEAT_VMOTION:_______@___________________________:winx64 Â 7876:172.23.240.1 Â Â
2023/07/24 16:38:14 Â Â NEW_CONNECTION Â Â Â Connected to Licensing Client Proxy server: 63892@127.0.0.1.
2023/07/24 16:38:14   CHECKOUT       vmotion_post           23.2 (2023.0505)       1/1/1/1         6/6/7/7  32928:FEAT_VMOTION:_______@___________________________:winx64  7876:172.23.240.1  Â
2023/07/24 16:38:14 Â Â CHECKOUT Â Â Â Â Â Â vmotion_post (Share) Â Â Â Â Â Â 23.2 (2023.0505) Â Â Â Â Â Â 1/-/-/- Â Â Â Â Â Â Â Â 6/6/7/7 Â 32928:FEAT_VMOTION:_______@___________________________:winx64 Â 7876:172.23.240.1 Â Â -
July 25, 2023 at 12:27 pm
Marcelo Precoppe
SubscriberRegarding your request to check the increment on the license file, I do not have access to it (I can request our license server manager to have a look at it if necessary), but running the Diagnostics tool from ANSYS Licensing Settings 2023 R2, the following information is shown regarding vmotion_post:
Feature             Version   #licenses   Vendor     Expires
_______ Â Â Â Â Â Â Â Â Â Â Â Â _________ Â _________ Â Â ______ Â Â Â Â ________
vmotion_post           9999.9999   1      ansyslmd    27-oct-2023
vmotion_post           9999.9999   1      ansyslmd    30-oct-2023 -
July 25, 2023 at 12:46 pm
George Karnos
Ansys EmployeeWhat is the name of the download package that you installed 2023 R2 from?
What is contained in theÂ
c:\Program Files\Ansys Inc\install.logConcerning 2023 R2
July 25, 2023 at 12:56 pm
Marcelo Precoppe
SubscriberANSYS 2023 R2 products were installed from the "Fluids and Structures" package.
Concerning 2023 R2, the following content is shown in the install.log file located at C:\Program Files\Ansys Inc\ (username has been replaced with "_____")>>>--------------------------------------->
Start Installation: Tue Jul 18 12:35:35 2023
Revision: 2023 R2Platform specifics:
  Windows
Username of Installer: STAFF\________
User Has Administrator Privileges
C:\Users\________\AppData\Local\Temp\ans_install_tmp27796\instcore.exe -usetempdir C:\Users\________\AppData\Local\Temp\ans_install_tmp27796 -launchdir C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64 -admin
Initial mount directory:
Installation Directory:
  C:\Program Files\ANSYS IncWindows x64
   Ansys, Inc. Products
     Discovery
        Discovery
     Fluid Dynamics
        Fluent (includes CFD-Post)
     Motion
     Structural Mechanics
        Mechanical Products
   Ansys Additional Tools
     Viewer
   Ansys Geometry Interfaces
     ACIS Geometry Interface
     AutoCAD Geometry Interface
     Catia, Version 4 Geometry Interface
     Catia, Version 5 Geometry Interface
     Catia, Version 6 Geometry Interface
     Creo Parametric Geometry Interface
     Inventor Geometry Interface
     JTOpen Geometry Interface
     NX Geometry Interface
     Parasolid Geometry InterfaceÂ
     Solid Edge Geometry Interface
     SOLIDWORKS Geometry Interface
     SpaceClaim Geometry Interface
Licensing files on the installation media have the same date or are more recent than those currently installed.
   The files will be updated....
Date verification complete...Please see above messages for any detected conflicts.The installation will copy the prerequisite setup files from the media in case you need to reconfigure later or if you need to configure client machines for products installed to a network share.
This may take a while ...
Successfully copied prerequisites from media.You're missing required prerequisites.
Installing MS ASP.NET Hosting Bundle 6.0.16
Installing MS Desktop Runtime 6.0.16
Everything was successfully installed.Reading the installation media contents - please wait.
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\framewrk\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\instcore\tcl\COMMON.TGZ ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\instcore\tcl\WINX64.TGZ ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\license\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\hlp\hlplic\HLPLIC.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\instutil\INSTUTIL.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\instcore\tk\COMMON.TGZ ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\instcore\tk\WINX64.TGZ ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\configs\clientlicensing\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\clclient\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\subs\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\disco\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\configs\ansconfigdll\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\configs\wb\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addins\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addins\ansoft\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addins\matdes\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addincfg\wb\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\corewb\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cads\cadaisol\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cads\cadregistry\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addins\injmold\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addincfg\minerva\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\meshing\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\pyprime\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\apipsrv\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\syscplg\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\mechsrvplg\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\dpf\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\dpf\plugins\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\dpf\plugins_autodyn\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\rsm\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\icemwb\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addincfg\turbosys\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cads\acispara\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\sec\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\disco_explore\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\disco_overlay_resources\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\configs\disco\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addins\apiserver\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\ccm\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\blademodeler\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cads\fusion\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\configs\spaceclm\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\ecadxltr\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cads\spatialiop\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addincfg\granta_gateway\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addins\granta_gateway\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addincfg\granta_selector\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addins\granta_selector\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cff\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\fluenta\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\fluentc\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\fluentm\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\fluents\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\fluentp\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\fluent3ddp\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\sgcharts\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\fwgfx\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\common\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\commoninstall\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\configs\common\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cpythext\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cpythnew\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cpythcloudext\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\hlp\hlpviewer\HLPVIEWER.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\configs\help\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\7zip\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\angular-nvd3\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\angular-ui-context-menu\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\angular-ui-tree\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\angularjs\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\angularjs-slider\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\angularui\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\bootstrap\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\d3\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\ffmpeg\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\IntelCompiler\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\jquery\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\ngInfiniteScroll\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\nvd3\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\qt\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\signalr\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\hdf5\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\zlib\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\ansys\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addprintgeometry\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\configs\ansys\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addincfg\ansys\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\solver\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\data\DATA.GZ ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\apdl\APDL.GZ ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\python_site_mapdl\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addincfg\mech\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\dpf\plugins_composites\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\aas\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cfxcomon\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cads\stride\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cads\hoops\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\geompara\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\designmodeler\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\artemis\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\lumerical\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\intelmkl2020.0.166\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\intelmkl2021.3.0\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\fluentu\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\fluent2d\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\fluent2ddp\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\fluent3d\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addincfg\fluent\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\configs\fluent\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\distcomp\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\post\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addincfg\cfdpost\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\configs\cfdpost\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\ensight_components\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\nexus\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\polyflow\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addincfg\polyflow\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addincfg\matpro\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\configs\polyflow\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\ensight\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\configs\ensight\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\openjre\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\spaceclm\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\tp\cpprestsdk\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\motion\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\motion_scdm_addin\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\configs\motion\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addincfg\matdes\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\acp\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\addins\acp\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\configs\acp\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\shapeoptimization\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\additive_cl\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\aview\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\configs\aview\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cads\acad\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cads\cat5\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cads\datakit\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cads\osm\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\geomproe\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cads\pe\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cads\ai\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\geomunig\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cads\nx\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cads\se\WINX64.7z ...
 Extraction: C:\Users\________\Downloads\FLUIDSTRUCTURES_2023R2_WINX64\cads\sw\WINX64.7z ...
RSS is disabledPerforming licensing configuration via the following command...
  C:\Program Files\ANSYS Inc\v232\licensingclient\winx64\LicensingSettings.exe fnp server add --inputÂLicensing configuration has completed.
Creating Start Menu items for Ansys client licensing ...
Running C:\Program Files\ANSYS Inc\v232\commonfiles\configs\winx64\config\AnsConfigSpaceClaim.exeRunning C:\Program Files\ANSYS Inc\v232\commonfiles\configs\winx64\config\AnsConfigDisco.exe
Running C:\Program Files\ANSYS Inc\v232\commonfiles\configs\winx64\config\AnsConfigCommon.exe
Running C:\Program Files\ANSYS Inc\v232\Framework\bin\Win64\Ans.DriverSetup.exe
Running C:\Program Files\ANSYS Inc\v232\commonfiles\configs\winx64\config\AnsConfigFLUENT.exe
Configuring ANSYS CFD Post ...Running C:\Program Files\ANSYS Inc\v232\commonfiles\configs\winx64\config\AnsConfigCFDPost.exe
Running C:\Program Files\ANSYS Inc\v232\commonfiles\configs\winx64\config\AnsConfigPolyflow.exe
Configuring EnSight ...Running C:\Program Files\ANSYS Inc\v232\commonfiles\configs\winx64\config\AnsConfigEnsight.exe
Configuring Help ...Running C:\Program Files\ANSYS Inc\v232\commonfiles\configs\winx64\config\AnsConfigHelp.exe
ANSYS Internet Doc has been configured.
Running C:\Program Files\ANSYS Inc\v232\commonfiles\configs\winx64\config\AnsConfigWB.exe
Running "C:\Program Files\ANSYS Inc\v232\RSM\bin\AnsConfigRSM.exe" -encodingUTF8Configuring RSM...
Configuring default RSM and ARC Port numbers for 2023 R2 ...
Done!
User has Administrator privileges
Creating Start Menu Shortcut for RSM 2023 R2 Configuration...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2023 R2\Remote Solve Manager\RSM Configuration 2023 R2.lnk
Creating Start Menu Shortcut for RSM 2023 R2 Job Monitor...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2023 R2\Remote Solve Manager\RSM Job Monitoring 2023 R2.lnk
Creating Start Menu Shortcut for RSM 2023 R2 Cluster Monitor...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2023 R2\Remote Solve Manager\RSM Cluster Monitoring 2023 R2.lnk
Creating Start Menu Shortcut for ARC 2023 R2 Configuration...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2023 R2\Remote Solve Manager\ARC Configuration 2023 R2.lnk
Creating Start Menu Shortcut for DCG 2023 R2 Configuration...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2023 R2\Remote Solve Manager\DCG Configuration 2023 R2.lnk
Created Shortcut C:\Program Files\ANSYS Inc\v232\RSM\bin\HPCServices\DCG Local Portal.lnk
Created Shortcut C:\Program Files\ANSYS Inc\v232\RSM\bin\HPCServices\DCG Local Shutdown.lnk
Configuring Motion ...Running C:\Program Files\ANSYS Inc\v232\commonfiles\configs\winx64\config\AnsConfigMotion.exe
Running C:\Program Files\ANSYS Inc\v232\commonfiles\configs\winx64\config\AnsConfigANSYS.exe
Adding write permissions for Users and Administrators group ...
Configuring ACP ...Running C:\Program Files\ANSYS Inc\v232\commonfiles\configs\winx64\config\AnsConfigACP.exe
Configuring ANSYS Viewer ...
Running "C:\Program Files\ANSYS Inc\v232\aisol\..\commonfiles\CAD\bin\winx64\Ans.CadInt.CADConfigurationUtility.exe"Â
Log files is C:\Program Files\ANSYS Inc\v232\CADConfigLogs\Latest\CADConfigurationMgr.log
MessageLogger.logFilePath is C:\Program Files\ANSYS Inc\v232\CADConfigLogs\Latest\CADConfigurationMgr.log
ErrorLogger.errorFilePath is C:\Program Files\ANSYS Inc\v232\CADConfigLogs\CADConfigurationMgr.err
Prerequisites ..... Configure Success
SC  Workbench  PlugIn ..... Configure Success
Discovery Workbench Plugin ..... Configure Success
CatiaV4 Workbench Reader ..... Configure Success
CatiaV6 Workbench Reader ..... Configure Success
JT Â Workbench Reader ..... Configure Success
CP Â Workbench Reader ..... Configure Success
CATIAV5 Â Workbench Reader ..... Configure Success
NX Â Workbench Reader ..... Configure Success
SW Â Workbench Reader ..... Configure Success
AI Â Workbench Reader ..... Configure Success
ACAD Â Workbench Reader ..... Configure Success
SE Â Workbench Reader ..... Configure Success
Successfully created file associations.
Installation Complete: Tue Jul 18 12:44:48 2023
Installation Complete.ÂThanks for choosing Ansys Products!
***IMPORTANT***
After completing this installation, you need to run the Ansys, Inc. License Manager installation on each machine designated as a license server. Â These machines may have been specified during this installation or may have been previously specified. -
July 26, 2023 at 7:07 am
Marcelo Precoppe
SubscriberHello George,
Further to your earlier question regarding the increment line for vmotion_post, I realized we have two licenses in our license server, one was sent to us by email, and the other we downloaded via the license portal. I don't have access to the second one and have written to the IT department to look at it, but here is the increment line for vmotion_post of the license sent to us by email:
INCREMENT vmotion_post ansyslmd 9999.9999 27-oct-2023 1 CC9D7913CC05 \
  VENDOR_STRING="eval customer:88888888" ISSUER=ANSYS_SSL \
  ISSUED=28-oct-2022 START=28-oct-2022 SIGN2="009F 5D28 DEDC \
  2465 3120 2A39 AC10 0200 D5AF 7555 971A 4992 ED13 F199 2988" -
July 27, 2023 at 8:54 am
Marcelo Precoppe
SubscriberDear George,
Do you need any further input from my side in other to provide a solution to this problem? Please let me know.
Kind regards,
Marcelo -
July 27, 2023 at 9:07 am
Nanda
George was Out of Office yesterday, He will return today and continue this discussion. Meanwhile I'll ask any other engineer's who are familiar with licensing and installation issues. Me and george tested a chain pulley assembly, which had around 68 bodies. It worked fine on our machine. We do not have an academic license, but a commercial and academic research license have same features and limitations, just different terms and conditions. Probably george can look at those "increment line" stuff and provide his thoughts.
Nanda
July 27, 2023 at 9:50 am
Marcelo Precoppe
Thanks for the prompt reply. Just a question to make sure there are no misunderstandings. After you have run the chain pulley assembly, did you try opening Ansys Motion Postprocessor (from inside Ansys Mechanical) as shown below? I have no problem running the simulation. I just face the issue when I want to analyze the results using Ansys Motion Postprocessor, as shown:
July 27, 2023 at 10:13 am
July 27, 2023 at 10:18 am
Marcelo Precoppe
Thanks for the update. I don't think it is a machine-specific issue, as I am facing this problem on two different computers (connected to the same license server). It is most likely a license issue and probably related to the fact that we have received two separate licenses, one downloaded from the license portal, and one received by e-mail. Hopefully, George can find a solution.
Kind regards,
Marcelo -
July 27, 2023 at 3:36 pm
Marcelo Precoppe
I have now received the increment from the license on the server (I have replaced the customer number with "_______":
INCREMENT vmotion_post ansyslmd 9999.9999 30-oct-2023 1 D611AA76A6DE \
  VENDOR_STRING="customer:_______ tp:a" SUPERSEDE ISSUER=SIEBEL \
  ISSUED=25-jul-2023 START=01-jul-2022 SIGN="00FE A459 ADAB F138 \
  5C62 3E00 66BB FF00 5461 8820 B487 6B38 93CF AD49 5358" \
  SIGN2="0089 8589 2A0A 95EA 3BD3 D93C 9039 4200 0F94 A2B3 6E09 \
  643C 8996 9263 EC6F"
I hope this information allows you to guide us in solving this issue.
Kind regards,
Marcelo -
July 27, 2023 at 5:10 pm
July 27, 2023 at 6:31 pm
George Karnos
Ansys EmployeeHi Marcelo,
My apologies for the delay!
When in Mechanical, (before selecting Run Postprocessor)which license are you using?
I am trying to replicate your issue on my machine.
Would it be possible to send me the first part of the license file from the license server:
C:\Program Files\ANSYS Inc\Shared Files\Licensing\license_files\ansyslmd.lic
Example:SERVER LicServer 0050568903eb 1055
VENDOR ansyslmd
USE_SERVER# Products licensed in this file:
# 1. ANSYS Mechanical Enterprise: 10 task(s) Lease expiring 23-Sep-2022 Customer # 1111111
# 2. ANSYS optiSLang Enterprise: 10 task(s) Lease expiring 23-Sep-2022 Customer # 1111111
# 3. ANSYS GRANTA Selector: 10 task(s) Lease expiring 23-Sep-2022 Customer # 1111111Particularly the "#Products in this file:" section
July 27, 2023 at 7:02 pm
Marcelo Precoppe
SubscriberHi George,
I appreciate your help. This is how the first part of the license at the license server looks like (server name replaced with "____":SERVER _____.___.AC.UK 0050568a37d7 1055VENDOR ansyslmdUSE_SERVERÂ# Products licensed in this file:# 1. Ansys Academic Research CFD (1 Task): 1 task(s) Lease expiring 29-Oct-2023 Customer # 614964# 2. Ansys Academic Research HPC (per core): 16 task(s) Lease expiring 29-Oct-2023 Customer # 614964# 3. Ansys Academic Research Mechanical (1 task): 1 task(s) Lease expiring 30-Oct-2023 Customer # 614964# 4. Ansys Academic Research Mechanical and CFD (1 task): 1 task(s) Lease expiring 30-Oct-2024 Customer # 614964# 1. All Active Increments: 1 task(s) Lease expiring 27-Oct-2023 -
July 27, 2023 at 7:17 pm
Marcelo Precoppe
SubscriberWhen Ansys Mechanical is open and I open the Ansys Licensing Settings 2023 R2, I see prepost license being used, as shown:
 "preppost" v9999.9999, vendor: ansyslmd, expiry: 30-oct-2023 vendor_string: customer:______ tp:a floating license  ______ M______.uk MP___________e.ac.uk 6456 (v2023.0505) (______/1055 305), start Thu 7/27 20:04Â
July 27, 2023 at 7:52 pm
George Karnos
Ansys Employee -
August 1, 2023 at 4:20 pm
Marcelo Precoppe
Are there any updates on this matter? Are you able to provide guidelines for an interim solution (i.e. modify the license file) so I can resume my work?Kind regards,
Marcelo
August 1, 2023 at 4:23 pm
George Karnos
I apologize for the delay. I have contacted development and am waiting on their response.Â
Kind Regards,
George -
August 3, 2023 at 2:03 pm
Marcelo Precoppe
As it seems the Product Development Team is taking time to provide an answer, can we work on an interim solution? As you were able to replicate it and determine is a license issue, would it be possible to generate a trial license, with similar products but without the "Academic Research" part that is causing the issue?
Thanks for helping me with this.
Kind regards,
Marcelo -
August 3, 2023 at 4:24 pm
George Karnos
I thank you for your patience!
I have contacted your account manager concerning the trial license.
Best Regards,
George Karnos
ANSYS Inc
5964
1307
