May 22, 2026 at 10:15 am
anuragparth24
SubscriberI have a body, i divided it in two part. First i do not share/force share the bodies but I get a non-conformal mesh. Seocnd I share the topology, i get a confromal mesh but it is a failed mesh (yellow color) . I dont know how to proceed or what to change in geometry. In the image below, it shows problematic geometry, which i dont understand like why it is problematic what is the cause. I would like to know the the solution or suggestions Thanking you
May 22, 2026 at 2:05 pm
peteroznewman
SubscriberIn SpaceClaim, under the Repair tab, use the Extra Edges button and then the Spit Edges button to clean up the geometry. On the Workbench tab, you might need to use the Share button again.
In Workbench, suppress all the mesh controls, but use a reasonable value for the Default Element Size and try meshing with no additional controls. Does that mesh with Hex elements or Tet elements? If it meshes with Tet elements, clear generated data and unsuppress a single Sweep mesh control for the rectangular body. Right click on that body and Generate Mesh on Selected Body. If that meshes cleanly, then Generate Mesh to mesh the second body. If that gives you a valid mesh, now you can selectively unsuppress the edge sizing mesh controls to get the element sizes you want.
May 25, 2026 at 12:28 am
anuragparth24
SubscriberIn spaceclaim no extra edges and split edges were found. After this I shared the geometry again in workbench tab.
In meshing without any controls valid mesh is generated(hexa elements).Â
I am only getting a valid mesh if generate the mesh individually for all the bodies not when i generate the mesh at once all together.
is the mesh generated by individually selected body work fine, if i export it in openfoam?  -
May 25, 2026 at 1:44 am
peteroznewman
SubscriberA mesh generated one body at a time is fine. You can export the mesh with a full license, but not with the Student license.
May 26, 2026 at 8:42 am
anuragparth24
SubscriberYes It is working, may I ask the reason, why it is working when generated individually not when I click on generate button, related to processing power or something else ? Â
May 26, 2026 at 9:43 am
peteroznewman
SubscriberThe reason is you are giving the mesher a simpler task when you tell it to mesh one body at a time.
May 26, 2026 at 10:26 am
anuragparth24
Subscriberokay, thanks for all the help.Â
6790
1331
1147
