July 11, 2021 at 11:59 pm
mzhossain2001
SubscriberHello.
It looks like the new student 2021 R1 version doesnt have Mechanical APDL. And there isn't any way to renew 2020 R2 after its expiry this year.
Also ansys student discovery has the capability for structural analysis but there isn't any mention to the details of those structural analysis it can do.
Thanks in advance for a reply/response.
July 12, 2021 at 10:42 amRob
Forum ModeratorP1 /forum/discussion/29465/is-there-a-way-to-renew-the-ansys-student-2020-r2-edition-whose-licence-is-valid-till-7-31-21#latest
P2 will be covered in the documentation. If' you're needing the full APDL interaction I suspect Discovery is not what you're after.
July 12, 2021 at 11:49 ammzhossain2001
SubscriberThanks Rob. 2021 R1 has ansys multiphysics and I am not sure if this is with Ansys apdl or. Ansys workbench. Any idea?
May 16, 2023 at 2:23 pmDhaval.patel2
Subscriber Hi Everyone,Â
Did anyone got this type of error while doing ansys modal analysis.
*** ERROR *** Â Â Â Â Â Â Â Â Â Â Â Â Â CP = Â Â 137.469 Â TIME= 10:22:18
 During the multiframe restart process, neither the .RDB file nor the  Â
 .Rnnn file was found.  Both files are required to perform the      Â
 multiframe restart for the linear perturbation analysis.  You must use Â
 the RESCONTROL,LINEAR command in the prior base analysis.  The     Â
 ANTYPE,,RESTART command is ignored. ÂSeptember 1, 2023 at 11:43 amyashwardhan.sahi
SubscriberViewing 4 reply threads- The topic ‘Ansys Mechanical Apdl’ is closed to new replies.
6625
1311
