December 29, 2023 at 4:13 am
anis mat
SubscriberHello, I have a question regarding running a simulation on ANSYS Mechanical APDL. I want to test the effect of a repeated load on a structure by applying a cyclic load of 300 kN for 2000 cycles with a frequency of 1 Hz. Which type of analysis should I use to observe the stress and strain of the structure for one cycle, 300 cycles, and so on? Also, could you please guide me on how to set the number of cycles using the command or main menu?
December 29, 2023 at 8:21 am
ErKo
Ansys EmployeeDuplicate.
Use this discussion:
/forum/forums/topic/ansys-mechanical-apdl-2/
Closing.
- The topic ‘ANSYS MECHANICAL APDL’ is closed to new replies.
