May 24, 2024 at 7:54 pm
melikeoztopal
SubscriberHi, I am a newbie in Maxwell, and I am trying to simulate a rotating circular arrangement of permanent magnets. To set up the motion, I created a segmented cylinder enclosing the wheel. However, when I run the analysis, it always gives the following error:
"Error in mesh mapping on band, please check the potential problem in band setting.
Simulation completed with execution error on server: Local Machine."
Despite my efforts, I could not sort the problem out. Any help would be very much appreciated. Thank you.
June 5, 2024 at 9:02 pm
HDLI
Ansys EmployeeHello Melike,
Could you add innerBand, that is smaller than Band and bigger than all the moving objects? Thanks.
HDLI
- The topic ‘Ansys Maxwell “mesh mapping on map” error’ is closed to new replies.
- Co-simulation in Q3D, Icepak – meshing problem
- Classic Icepak – clarifications on Boundary condition
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
1495
1386
1209
