February 25, 2026 at 11:12 am
grigorios.sergentanis
SubscriberÂ
Hi All,
I'd like to export B field data over time from my 2D-Transient simulation into a .csv file eventually. I'm trying to do this using the Fields Report -> Data Table method, but I need the field data over a rectangular area; I have a rectangle defined in the geometry, but I cannot get it to show in the context. Does anyone know how to achieve this? I'm aiming for a 3 dimensional matrix with (X,Y,Time) variables and MagB as the result.
February 25, 2026 at 3:07 pm
NKC
Forum ModeratorÂ
Hi grigorios.sergentanis,
To export the B field (MagB) data over time from your 2D-Transient simulation in Ansys Maxwell, you need to use the Fields Calculator
- Open the Fields Calculator after your simulation has completed.
- Set the Quantity to B and choose Mag for the vector operation.
- For geometry selection, choose the surface corresponding to your rectangular area. If the rectangle does not appear in the context, ensure it is properly defined as a selectable object in the geometry setup. You may need to re-define or re-import the rectangle as a named surface or region.
- Go to Output and select Export. Specify the grid points or coordinate range covering your rectangle. You can manually input the grid, or import from an external file if you have the mesh coordinates.
- Set the file name and format (typically .txt or .json). The exported file will contain columns for X, Y, (Z if 3D), and MagB values.
- Repeat the export for each time step,Â
- Convert the exported file to .csv format
Regards
Navya
February 25, 2026 at 3:15 pm
SubscriberHello Navya,
Thank you for your reply. Can you let me know where you've found the transient export option please? I do not see it in Maxwell, and I did a quick lookup on the manual where it also returns no results. I'm looking to avoid doing it manually once per timestep, as there are quite a few of them.
Kind regards,
Greg
February 25, 2026 at 3:37 pm
NKC
Forum ModeratorÂ
I just looked it up, and it is not in the field calculator process, but while plotting the field, where we select multiple time steps.
That stepis not for the field calculator.
Apologies for the confusion.Â
5199
1859
1387
1250
