June 20, 2023 at 1:51 pm
Chethan
SubscriberI have designed a soft electromagnetic actuator using Ansys Maxwell 3D module on Ansys Electronics Desktop. I want to perform a mechanical simulation of the same setup on Ansys Mechanical. How can I transfer this entire setup (including magnetic field, current excitations, and resultant volume-force fields) to Ansys Mechanical for stress analysis?
June 20, 2023 at 3:17 pm
DELI
Ansys EmployeeHi, magnetic field and current excitations will not be transferred through the link, but force and loss data can be linked from Maxwell to Ansys Mechanical. In order to linking force and loss data, you will need use Ansys Workbench to couple Maxwell and Ansys Mechanical. -
June 20, 2023 at 6:45 pm
Chethan
SubscriberYes, I think the Force distribution would be good enough for me to find the stress,strain and deformations of the actuator. Could you please be more elaborate about the process of how it can be done in workbench?
- The topic ‘Ansys Maxwell and Ansys Mechanical’ is closed to new replies.
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- 2D transient simulation -torque issue
- Two way coupling for Maxwell and thermal problem
1510
1386
1209
