July 1, 2020 at 10:04 am
Ayman
SubscriberHow could I define a fracture damage material in AnsysÂ
July 1, 2020 at 7:59 pm
Wenlong
Ansys EmployeeHi Ayman,Â
What material are you trying to model? What is your analysis type? Static Structural or Explicit dynamics?
To get started:
1. Johnson-Cook material in Explicit (https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/exd_ag/ds_ex_mat_johncookf.html)
2. Damage initiation and evolution law can be used for composite (https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/ans_mat/mat_damageall.html?q=damage)
3. Microplane material model is well suited for simulating engineering materials consisting of various aggregate compositions with differing properties such as concrete (https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/ans_mat/microplane.html?q=damage)
4. RHT model is also for concrete in explicit (https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/exd_ag/ds_ex_mat_rhtconc.html)
Wenlong
================ Note ====================
If you have trouble opening the links I attached, please see the first useful link below
Useful Links
- How to access Ansys Online Help Document
- How to show full resolution image
- How to use Google to search within Ansys Student Community
July 5, 2020 at 8:30 pm
Ayman
Subscriber Hi Wenlog,
I study a connection between steel hollow box section column and beam under a moment (static structure) and my doctor send me material he has used in Abaqus to measure the fracture damage and ask me to apply it in Ansys but I can't find any similar material behaviour like this in Ansys
.jpg?width=690&upscale=false)
so if you can help me to apply it or find out how to simulate it.
sorry for my late reply and thanks in advance.
July 7, 2020 at 8:49 pm
Wenlong
Ansys EmployeeHi,
I don't recall material models that's directly related to ductile damage with stress triaxiality but that can be the limit of my knowledge. The damage initiation and evolution is more geared towards composite materials and doesn't consider strain rate. Gurson material model does have damage and is for metal.
Did you use explicit or static in Abaqus? I asked because this type of behavior is typically hard to converge in static structural analysis. In Ansys LS-DYNA and explicit dynamics, there are ductile damage/fracture materials you can use such as Johson-cook.Â
Wenlong
November 7, 2023 at 2:35 am
Sebak Oli
SubscriberÂ
Hi Ayman,
I ran into the exact problem. In Abaqus there is a way to input the plastic displacement and the corresponding damage variable for ductile damage but couldn’t find a exact way to do it in APDL. Did you resolve the issue?
Can anyone suggest any appropriate way?
- The topic ‘Ansys material damage’ is closed to new replies.
6495
