November 3, 2018 at 6:59 pm
NajjibGuerra
SubscriberHi guys!  I´m trying to install ANSYS on my computer, but this message appears when I try to add a License Key.
Do you guys know the solution to this problem?
November 5, 2018 at 6:41 pm
tsiriaks
Ansys EmployeeHi NajjibGuerra ,
This means the License Manager on your machine is set to run as a non-default mode. You can easily change this mode back to default in 'Specify License Manager Run Mode' . However, you must make sure that the license file is supposed to be installed on your machine first (check if it's issued for your machine or some remote license server machine). If it's not issued for your machine, just leave this mode as-is and don't install license file on your machine.
Thanks,
Win
November 5, 2018 at 6:47 pm
NajjibGuerra
SubscriberThanks, tsiriaks! I´ve one question, How do I know if I had the license file on my computer?Â
Najjib Guerra
November 5, 2018 at 7:04 pm
tsiriaks
Ansys EmployeeHi Najjib,
Have you received a license file from an ANSYS representative ? If so, open up that license file and look at the 'SERVER' line to see if the hostname on there is your computer hostname or not. If not, this is not for you. Or if you don't receive a license file at all, then you don't need to start your local License Manager as well.
Thank you,
Win
November 5, 2018 at 8:25 pm
NajjibGuerra
SubscriberHi Win,
Yes, I received a license file and also in the SERVER line is my computer hostname. But I don´t have a .rar of Ansys, so I really don´t know how to install that version, I´ve been only able to install the student version. Do you know a tutorial or some steps in order to install it?
ThanksÂ
Najjib Guerra
November 5, 2018 at 8:40 pm
tsiriaks
Ansys EmployeeHi Najjib ,
Login to ANSYS Customer portal -> Downloads -> Current Release , you can download the products from here. Then, the installation guides would be under Download ->Â Installation and Licensing Help and Tutorials
Just want to make sure, so right now, you can install the license file to your ANSYS License Manager correctly, right (after changing the 'run mode' back to default) ?
Thanks,
Win
November 6, 2018 at 5:04 am
NajjibGuerra
SubscriberHi Win,
Thank you for your support! I´ve already tried to sing in with mi student account, and i couldn´t do it, do i have to create a new account?Â
And On the License Manager ,this message pops up
And when I try to add the license file, this message pops up:
So, I don´t really know what am I doing incorrectly, I enter the license txt on the "Run the ANSYS Licensing Interconnect with FlexNet  (default)" Because I really didn´t know what file has to be there.
Thanks for your time!
Najjib Guerra
November 6, 2018 at 5:31 pm
tsiriaks
The customer portal requires a different registration than your student account. The customer portal is only valid for those who have paid ANSYS license (which you do). You can click register on the login page. Make sure you have customer/account # in hand. If you don't know this number, you can check it from your license file. It would be at the end of the line that lists licenses, e.g., Customer #Â 12345678
For the issue starting License Manager, please click View Licensing Interconnect Log, then search for the latest 'Normal Startup' line and copy and paste everything after this line and post it here.
Thank you,
Win
November 6, 2018 at 6:33 pm
NajjibGuerra
SubscriberHi Win,
Thanks for your information, I´ve already created an account on the customer portal.Â
And This are the lines for the Licensing Interconnect Log.Â
NORMAL STARTUP 2018/11/06 12:28:46
ANSYS Licensing Interconnect version 1.9.3 (20180409) for winx64. Updated at ANSYS Build 19.1. Started on 2018/11/06 12:28:46 by SYSTEM@DESKTOP-QQBF4SB:winx64 with pid 15208. (C) 2007 - 2018 ANSYS, Inc. Unauthorized use, distribution, or duplication is prohibited. Built Using FlexNet Publisher v11.13.1.4 build 179569 x64_n6 Built Using OpenSSL 1.1.0g 2 Nov 2017
Please note that entries in this debug log have the following format: TIMESTAMP ACTION FEATURE REVISION (BUILD DATE) A/B/C/D W/X/Y/Z PID:MPID:APP:USER@HOST
LATFORM
ISPLAY SOCKET:IP Licenses statistics:
A is the number of licenses requested by this ACTION. B is the number of licenses used by this USER. C is the number of licenses used by all users. D is the number of licenses available in the local license pool. License server performance statistics:
W is the number of currently connected client applications. X is the maximum number of connected client applications. Y is the unique serial number of this client application. Z is the number of all client applications served by this Licensing Interconnect server.
2018/11/06 12:28:46 INFO ANSYSLI_CMD=C:Program FilesANSYS IncShared FilesLicensingwinx64ansysli_server.exe -nodaemon 2018/11/06 12:28:46 INFO ANSYSLI_INITIALIZATION_FILE='C:Program FilesANSYS IncShared FilesLicensingansyslmd.ini' 2018/11/06 12:28:46 INFO ANSYSLI_MONITOR=C:Program FilesANSYS IncShared FilesLicensingwinx64ansysli_monitor.exe 2018/11/06 12:28:46 INFO ANSYSLI_PRODORD_FILE='C:Program FilesANSYS IncShared FilesLicensingprodordansysli.prodord.xml' 2018/11/06 12:28:46 INFO FLEXLM_LICENSE_FILE='C:Program FilesANSYS IncShared FilesLicensinglicense_files' 2018/11/06 12:28:46 INFO ANSYSLI_PORT=2325 2018/11/06 12:28:46 INFO Backing up FLEXlm debug log file to C:Program FilesANSYS IncShared FilesLicensinglogs_backuplicense_20181106_122846.log. 2018/11/06 12:28:46 ERROR Could not backup to C:Program FilesANSYS IncShared FilesLicensinglogs_backuplicense_20181106_122846.log. Make sure you have write permissions. 2018/11/06 12:28:46 INFO C:Program FilesANSYS IncShared FilesLicensingwinx64lmgrd.exe -c "C:Program FilesANSYS IncShared FilesLicensinglicense_files" -l "C:Program FilesANSYS IncShared FilesLicensinglicense.log" 2018/11/06 12:28:48 INFO Still trying to start FLEXlm server. Please wait ... 2018/11/06 12:28:52 CACHE_SERVER Available licenses from file C:Program FilesANSYS IncShared FilesLicensinglicense_files: 10 a_spaceclaim_catv5 10 a_spaceclaim_dirmod 5 aa_mcad 5 aa_r 32 aa_r_hpc 5 afsp_gui 5 afsp_optigrid 5 afsp_viewmerical 10 aice_mesher 10 aice_opt 10 aice_pak 10 aice_solv 10 aiiges 5 aim_mp1 5 al4allegro 5 al4ansoft 5 al4apd 5 al4boardstation 5 al4cadvance 5 al4cds 5 al4expedition 5 al4first 5 al4gem 5 al4generic 5 al4odb++ 5 al4powerpcb 5 al4virtuoso 5 al4zuken 80 ansoft_distrib_engine 5 designer_hspice 10 electronics2d_gui 10 electronics3d_gui 10 electronics_desktop 10 electronicsckt_gui 10 emit_legacy_gui 5 emit_solve 5 ensemble_25_sim 5 filter_synthesis 5 hfss_solve 5 hfss_transient_solve 192 hfsshpc 5 hfsssbr_solve 5 m2dfs_qs_solve 5 m2dfs_solve 5 m3dfs_qs_solve 5 m3dfs_solve 5 maxwlspc 5 nexxim_ami 5 nexxim_dc 5 nexxim_eye 5 nexxim_hb 10 nexxim_netlist 5 nexxim_osc 5 nexxim_tran 5 nexxim_tvnoise 10 optimetrics 5 pemag 5 pexprt 5 rmxprt_bcm 5 rmxprt_ecm 5 rmxprt_im 5 rmxprt_sym 10 savant_legacy_gui 10 si2d_solve 10 si3d_solve 5 simplorer_advanced 5 simplorer_control 5 simplorer_cprogrinterface 10 simplorer_gui 5 simplorer_libsmps 5 simplorer_model_export 5 simplorer_modelica 5 simplorer_sim 5 simplorer_sim_entry 5 simplorer_vhdlams 10 siwave_gui 10 siwave_level1 10 siwave_level2 10 siwave_level3 5 symphony_dt_sim 5 symphony_fd_sim 10 xlate_catia4 10 xlate_catia5 10 xlate_iges 10 xlate_inventor 10 xlate_parasolid 10 xlate_proe 10 xlate_solidworks 10 xlate_step 10 xlate_unigraphics 2018/11/06 12:28:52 CACHE_SERVER No active FLEXlm options. 2018/11/06 12:28:52 CACHE_SERVER No active ANSYS Licensing Interconnect options. 2018/11/06 12:28:58 INFO Still trying to start FLEXlm server. Please wait ... 2018/11/06 12:29:08 INFO Still trying to start FLEXlm server. Please wait ... 2018/11/06 12:29:18 INFO Still trying to start FLEXlm server. Please wait ... 2018/11/06 12:29:28 INFO Still trying to start FLEXlm server. Please wait ... 2018/11/06 12:29
8 INFO Still trying to start FLEXlm server. Please wait ... 2018/11/06 12:29:48 INFO Still trying to start FLEXlm server. Please wait ... 2018/11/06 12:29:58 INFO Still trying to start FLEXlm server. Please wait ... 2018/11/06 12
0:08 INFO Still trying to start FLEXlm server. Please wait ... 2018/11/06 12
0:18 INFO Still trying to start FLEXlm server. Please wait ... 2018/11/06 12
0:28 INFO Still trying to start FLEXlm server. Please wait ... 2018/11/06 12
0
0:48 INFO Still trying to start FLEXlm server. Please wait ...
November 6, 2018 at 8:48 pm
tsiriaks
It cannot start FlexLM for some reason. Please post the content of the 'View Flexnet Debug Log'
Thanks,
Win
November 7, 2018 at 10:18 pm
NajjibGuerra
Subscriber9:23:52 (lmgrd)
9:23:52 (lmgrd) Please Note: 9:23:52 (lmgrd) 9:23:52 (lmgrd) This log is intended for debug purposes only. 9:23:52 (lmgrd) In order to capture accurate license 9:23:52 (lmgrd) usage data into an organized repository, 9:23:52 (lmgrd) please enable report logging. Use Flexera Software LLC's 9:23:52 (lmgrd) software license administration solution, 9:23:52 (lmgrd) FlexNet Manager, to readily gain visibility 9:23:52 (lmgrd) into license usage data and to create 9:23:52 (lmgrd) insightful reports on critical information like 9:23:52 (lmgrd) license availability and usage. FlexNet Manager 9:23:52 (lmgrd) can be fully automated to run these reports on 9:23:52 (lmgrd) schedule and can be used to track license 9:23:52 (lmgrd) servers and usage across a heterogeneous 9:23:52 (lmgrd) network of servers including Windows NT, Linux 9:23:52 (lmgrd) and UNIX. Contact Flexera Software LLC at 9:23:52 (lmgrd) www.flexerasoftware.com for more details on how to 9:23:52 (lmgrd) obtain an evaluation copy of FlexNet Manager 9:23:52 (lmgrd) for your enterprise. 9:23:52 (lmgrd) 9:23:52 (lmgrd)
9:23:52 (lmgrd) 9:23:52 (lmgrd) 9:23:52 (lmgrd) Server's System Date and Time: Mon Nov 05 2018 09:23:52 Hora est?ndar central (M?xico) 9:23:52 (lmgrd) pid 1012 9:23:52 (lmgrd) SLOG: Summary LOG statistics is enabled. 9:23:52 (lmgrd) Done rereading 9:23:52 (lmgrd) FlexNet Licensing (v11.13.1.3 build 176543 x64_n6) started on DESKTOP-QQBF4SB (IBM PC) (11/5/2018) 9:23:52 (lmgrd) Copyright (c) 1988-2015 Flexera Software LLC. All Rights Reserved. 9:23:52 (lmgrd) World Wide Web: http://www.flexerasoftware.com 9:23:52 (lmgrd) License file(s): C:Program FilesANSYS IncShared FilesLicensinglicense_filesansyslmd.lic 9:23:52 (lmgrd) lmgrd tcp-port 1055 9:23:52 (lmgrd) (@lmgrd-SLOG@) =============================================== 9:23:52 (lmgrd) (@lmgrd-SLOG@) === LMGRD === 9:23:52 (lmgrd) (@lmgrd-SLOG@) Start-Date: Mon Nov 05 2018 09:23:52 Hora est?ndar central (M?xico) 9:23:52 (lmgrd) (@lmgrd-SLOG@) PID: 1012 9:23:52 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.13.1.3 build 176543 x64_n6 ( build 176543 (ipv6)) 9:23:52 (lmgrd) (@lmgrd-SLOG@) 9:23:52 (lmgrd) (@lmgrd-SLOG@) === Network Info === 9:23:52 (lmgrd) (@lmgrd-SLOG@) Listening port: 1055 9:23:52 (lmgrd) (@lmgrd-SLOG@) 9:23:52 (lmgrd) (@lmgrd-SLOG@) === Startup Info === 9:23:52 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: No 9:23:52 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server 9:23:52 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c C:Program FilesANSYS IncShared FilesLicensinglicense_files -l C:Program FilesANSYS IncShared FilesLicensinglicense.log 9:23:52 (lmgrd) (@lmgrd-SLOG@) License file(s) used: C:Program FilesANSYS IncShared FilesLicensinglicense_filesansyslmd.lic 9:23:52 (lmgrd) (@lmgrd-SLOG@) =============================================== 9:23:52 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-4096 9:23:52 (lmgrd) Starting vendor daemons ... 9:23:53 (lmgrd) Started ansyslmd (pid 9324) 9:23:54 (ansyslmd) SLOG: Summary LOG statistics is enabled. 9:23:54 (ansyslmd) SLOG: FNPLS-INTERNAL-CKPT1 9:23:55 (ansyslmd) SLOG: VM Status: 0 9:23:55 (ansyslmd) SLOG: FNPLS-INTERNAL-CKPT2 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT aa_mcad ansyslmd 9999.9999 26-aug-2019 5 27C95DD7DF21 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 SIGN2="0072 EE9F 4174 6EBE C076 E366 01E8 5500 6B94 89EF 583B 32CB C923 91EE 90CE" 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT aa_r ansyslmd 9999.9999 26-aug-2019 5 6D33766B6FA9 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 SIGN2="0016 D81B 42F2 0716 2C07 FCEA 780C F200 B74E 843C A6C5 1BEE BD8C 0405 F285" 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT afsp_gui ansyslmd 9999.9999 26-aug-2019 5 A56CB2851716 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 SIGN2="00BB DB6F ADE6 9BC0 24AB A89E CD41 B400 B4A2 8939 6141 4187 F251 4A5B 35CF" 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT afsp_optigrid ansyslmd 9999.9999 26-aug-2019 5 E921127C697C VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 SIGN2="00BF 4293 E2B2 E2D0 448C E0C1 91E9 F500 E827 4D29 7E1C 431A B405 C4AA C3D6" 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT afsp_viewmerical ansyslmd 9999.9999 26-aug-2019 5 FAD632A22487 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 SIGN2="007D 951F DC8F 250D 3907 EAC8 50B2 D200 8E56 FBD5 15BE 821A ED36 B563 441B" 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT aim_mp1 ansyslmd 9999.9999 26-aug-2019 5 C8E9131F5989 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 SIGN2="00C7 35AD 1924 9728 99B2 0247 FE92 4000 96E3 D339 2D4B 2A1A EAFA 4F96 80B1" 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT a_spaceclaim_catv5 ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=F098045744F6 SIGN2="00C6 5682 69F6 6911 42FE A157 2223 8F00 6363 A57B 59AA B16C A9F1 1AE2 56A0") ansoftd=( SIGN="007E 45BC 0439 5CA5 1AD1 1242 068A 3F00 C9BF 773D B9C0 3BFD 7551 D8D0 E7E4" SIGN2="00DF BFF6 1025 3FEB F578 5C83 4DAF D600 52C1 5644 560A D1BD F647 2C21 BA8C") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT a_spaceclaim_dirmod ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=9682CA7B9162 SIGN2="00A0 DB4B 4009 0045 2178 C263 854F 4900 888C 93C7 45DB 241E 003F A437 E316") ansoftd=( SIGN="00E6 143B F37B 63D3 5DB4 E9C6 6E83 4200 1C72 B37B 7BBA BD4C 3818 43C4 841D" SIGN2="0091 4562 F0B9 0C9B 08CE 1429 F577 6C00 7CB4 3258 BC06 18D4 8BCC 6E1A 14A5") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT aice_mesher ansyslmd 9999.9999 26-aug-2019 10 57F0EA3A7B0A VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 SIGN2="003B 0F7A 9526 84A3 E40E C05E 5498 9600 A8BA 8238 B9C5 C9D3 ECDE 51F0 620B" 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT aice_opt ansyslmd 9999.9999 26-aug-2019 10 1835136B6F04 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 SIGN2="007E E0FC 109C B329 9320 DD83 0CAC B600 8822 D58B D95E BE22 1464 2BF5 272A" 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT aice_pak ansyslmd 9999.9999 26-aug-2019 10 E228931259BD VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 SIGN2="00AB 6DF7 A21F 4D29 C12D E50B 026F EE00 131B 6998 6ACD 341E 5633 04F6 9A17" 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT aice_solv ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=A05C33A57614 SIGN2="0053 1EED 750B 31CF 73DB D938 2175 C600 08CC 96A3 EE1B 0C98 A64A 4164 A496") ansoftd=( SIGN="00EE 9E45 D2FB 2FC5 70A4 9DF5 8E7D E200 8D80 6A20 7876 BA5C A595 3BC5 03FC" SIGN2="0001 44EF A843 3FD3 6666 0183 FC40 B100 407C AD79 0379 4E8A 1265 4A0A 54F3") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT aiiges ansyslmd 9999.9999 26-aug-2019 10 848A5AC04BFA VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 SIGN2="0083 0203 4DC2 8F83 FC3A B24C 51DE 3B00 ABCF C0E8 D83E 796B 160A B009 4511" 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT al4allegro ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=AFF332F31B11 SIGN2="0058 A368 CFA3 1BE2 7E66 2532 A44E 6E00 D535 5F9A 4A1D 1160 A833 257E 9662") ansoftd=( SIGN="0009 3E3A 51CF 3817 F5D6 093B 5D58 1C00 E410 DCB3 01AF DC29 029E 0F28 0ABD" SIGN2="0089 4972 7CFB E4A7 6281 8594 285E 1400 553E 90B6 7D56 04FC 2689 04AF 832F") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT al4ansoft ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=456800CAD2B8 SIGN2="0057 AB0A 92FC 3EBD 687B 2EBD F53A FE00 310D 28D0 8948 846B CB2E BBF2 0BF1") ansoftd=( SIGN="007D 7AF0 5334 0885 42B4 F873 3722 8300 FD32 0A93 E072 99C3 FD9C DCD0 1684" SIGN2="0083 ECBB 9187 D08B C135 5BCE 5ABE 3A00 0401 0655 96C1 FF9A A861 6C09 3144") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT al4apd ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=E49E2473421F SIGN2="0006 BCE8 6A1F 46DA 2CC2 97E3 4A3C 9000 7182 2C66 C8FE FFBE EB9F 0B8D 888B") ansoftd=( SIGN="00FF 08B2 0478 A5F4 7D05 6588 EF4A B700 ABC0 A1BD 75DC 0DF2 84AC 5AE6 CD85" SIGN2="00F0 B90D D711 AD81 949A 0634 068D E100 2D4B B6EB 8864 3C4A 9895 0466 8C88") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT al4boardstation ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=6CE29E68E1E3 SIGN2="000C 9E17 30BA 4E27 C155 FEA0 3103 FC00 720F 56D8 B4D6 EB66 93EC 0215 749F") ansoftd=( SIGN="0078 345D 766B 99FA AE94 5F96 5A7B 3200 9EED 9EBB 2FF6 4B29 BCBA 2E77 FFE4" SIGN2="006F 472D 9E32 7B71 C6A5 0849 C3FA E200 BD72 1058 10EB B503 173B 77DB 789F") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT al4cadvance ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=8DBD6E3FE726 SIGN2="0073 A2EE 7A27 BE03 1D85 5D57 616C A200 90FA 542A 86EF BF00 401A D76A 184C") ansoftd=( SIGN="0062 AA87 298F 9E63 7DF0 00DC BB62 1400 5437 528B F62A 1434 54CA F2FA CCB6" SIGN2="0012 0F0B F880 366D 6D28 BBE3 2105 5400 AB8D 0B0D 901E 4387 B6C3 3EAD 3BA3") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT al4cds ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=4C1148C9E5BC SIGN2="009E ACEA 426E C308 2109 9E20 194C 6300 C104 D89A 648B D0C0 4451 56CF 39CD") ansoftd=( SIGN="0035 D51F 88EE 70C5 E7AA 407F 8664 7100 0122 C096 7FF3 D156 1CBD A712 F083" SIGN2="0009 2999 BBBD 1D20 B0D7 91EE 6F32 E500 8A2F 1284 04E1 4D31 9885 5CA8 1F6D") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT al4expedition ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=7E868516144F SIGN2="0059 921A 3CFB 7890 F0FB 4E86 014E D300 CF71 AD4B 66D7 0953 9E4C 2888 FB58") ansoftd=( SIGN="000F EB32 84CC D82E 1ABF 378C BE5F 4900 51E7 7A6A 2DF0 9C14 4195 857A 103F" SIGN2="0082 9CA8 7415 C6BF 9F5A 029B 4590 8E00 D1DD 17FD 7F1D B9C5 D274 FB93 B65F") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT al4first ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=A138615C85A2 SIGN2="00DC 917E F533 3BD8 B1F4 B310 083B B700 697E 61DC EF8C 86F4 5263 7308 DC8D") ansoftd=( SIGN="0064 0D3C C1D7 CDC7 290A CD28 7D4A AB00 0A94 8FAA AC2F 7051 6B86 B200 3538" SIGN2="005E A430 2141 B6FE E10D 15CE 933D 8100 3A0A 5191 EBFC BC23 9356 351E 3746") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT al4gem ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=1B0BA1C9C665 SIGN2="00ED 1DDE B357 693B A5AD 6AA9 2854 7000 8FB1 41BB DD0B D033 8CBA 070F A783") ansoftd=( SIGN="00CF 950E E5D9 CB59 8082 64BD B1E3 6100 72CC 0119 4FF4 E8D6 95B1 6F8C 2B0A" SIGN2="00AC 88AA F464 0A5F B095 9DCE E11B 3000 8226 BF57 C114 0AE3 A51C BDD4 4D15") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT al4generic ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=0A2D48BF8F74 SIGN2="0031 F007 9E4B 77C6 2E11 BCC7 9564 5200 7C1A 9FB0 3CB4 644B 79D2 D4CB 6C95") ansoftd=( SIGN="0080 0EB1 9DC5 9870 5F3E 6CA2 E23B 3E00 A1CF BCF3 0F67 1109 7D74 D5E2 9918" SIGN2="00D8 BE8C 917B 4854 07A8 DBC2 EC7F C700 A93C 3463 6EFE DE6F 4488 574C 03FB") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT al4odb++ ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=AFFE51EE3AFB SIGN2="00C4 E2F3 783E BB1A C968 0FF0 07E5 EA00 983E 8F29 720D 17A0 1DC7 6622 0DDF") ansoftd=( SIGN="009F 65E2 1255 3021 0511 7FF3 6A0C AE00 AEEF 461B 67F5 5579 97BF 5DF6 3E74" SIGN2="00AC 38A2 3544 6F5F 27CB 567B B452 C000 3970 F9B7 106B E1E8 27CA 744F 1426") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT al4powerpcb ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=D3145C058704 SIGN2="00DC 6339 300E 38BA E22A 858C 9E73 A700 172B 2F8A 8790 4D7C FA66 4109 0DE9") ansoftd=( SIGN="009D ED71 3E61 A863 EB0A 21E9 D299 A300 CB5D 26E3 1EF8 82DC A06C 8295 9C6C" SIGN2="00AB B79C B9D9 7136 CB2A 7FF0 C561 A000 FF7F 9AF0 FB9F 7D64 1216 D42C CE5C") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT al4virtuoso ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=6A414F1AE46B SIGN2="00D8 35C6 89EA C234 22B3 4ABC 57DE FA00 04C6 26A3 B76F 6557 DB1D D14B A041") ansoftd=( SIGN="00D9 A614 00C3 5495 55B8 BF6D 5EFE BD00 DFB1 67D8 8D97 FE06 FE2C DC4D B930" SIGN2="00DC F505 EC9A D24A 0031 4972 5525 E500 8E55 62F2 8D10 0331 B014 F24E 6A0C") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT al4zuken ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=1FF02BB7F673 SIGN2="00FD 3E97 F629 BEF5 0129 AD25 D302 7F00 9032 C2F8 1DA0 B54A 0BB0 6DC7 58FA") ansoftd=( SIGN="00CC A242 EF4C D55F 3256 9EE2 67CF C200 0B9B B83F B7F5 FC6C 0DCE 4CFE A1BC" SIGN2="0072 28AF E134 E497 F382 B69A AEEE 6400 2D5D 16C8 658A 1CE2 D80B E44A 1420") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT ansoft_distrib_engine ansyslmd 9999.9999 26-aug-2019 80 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=4F915DD72C44 SIGN2="0086 C0D3 E610 AA7B B8A9 C40F 9B69 C500 ECC1 B147 DE23 DDAA 2F44 97EF FBE9") ansoftd=( SIGN="00FE 4FD1 8C82 675C FD3B B269 274F C800 7509 AD42 AD90 6126 0FE9 0E39 3EC3" SIGN2="006A 989A 509B CB8E DE12 C746 E262 7F00 ACEA 3EBA 80EA 266D 7823 5956 6F2D") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT designer_hspice ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=F98BF8AF5CB2 SIGN2="0001 0AA9 8AA8 0380 3190 4EBF 9B30 5A00 F9A5 C015 AE83 9B23 3409 6D03 D25D") ansoftd=( SIGN="00B9 3FAA C117 52B9 92F4 0375 2C5B 6600 5B0E A7C4 0F21 46F8 A855 F6EB DC0F" SIGN2="00E8 5BB2 320C 8FA2 63CE 1CAD 2B54 9F00 0563 2B7B 7A1C 1EE1 45F2 99EB D2A5") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT electronics_desktop ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=A630A5FBA4BA SIGN2="0023 9C71 7512 8AF3 E4CC 0F95 749D 7200 3FA6 E1B3 3CFF 0C39 CAD0 F422 2B8B") ansoftd=( SIGN="0045 D123 9AD7 666D 0C31 22F1 E483 F900 0E8D 250E 1ECF FC2D 34CD A559 CC62" SIGN2="00C0 7764 29E8 2FD7 ADFD 4FEB 2BB6 F000 7C02 1185 94DC E2A3 2C28 D763 11AE") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT electronics2d_gui ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=2F1CDCC96F12 SIGN2="00C2 EAC0 DB70 F8F8 C219 4B29 1006 9E00 A48F A887 93A7 162E 51BA 57EE B6B8") ansoftd=( SIGN="0086 05F6 9A76 2AE4 8C33 F512 D64C 9700 F4AF F965 EE7D 05A0 8941 1604 B33E" SIGN2="0005 EF29 8FBE 0CA2 9B1D 60E8 8D62 BB00 4C1C 508E DA58 77F4 B7E4 36CE 00EF") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT electronics3d_gui ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=9DB11EF7257F SIGN2="00C3 C5C3 E301 FFB9 40C9 72A1 0C27 CF00 B137 A621 6B01 A15B AAB8 22AE 19FF") ansoftd=( SIGN="0061 64DB 6A00 9BA6 0E57 153C 2143 9300 6811 4202 241B 773F AA6E 47E4 9721" SIGN2="0040 A2B6 D5B7 6EC2 3A38 A39A E438 AB00 209A A3AE 1461 E36C 2649 8F04 99B1") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT electronicsckt_gui ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=9889FDCDEEDB SIGN2="0061 9B13 FD64 EC49 BA14 7408 9D61 3300 8E85 DEF8 C787 A055 3C5B A662 D14C") ansoftd=( SIGN="007A 76CD D92D B9D7 3DDC 0A9F 24E5 2200 8BA2 DAAC 114F 00FA 5670 375D 665E" SIGN2="007E 2D54 5B43 C969 01F3 1909 2506 4E00 1C32 A79B 5016 096C A72B 4BE4 06CE") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT emit_legacy_gui ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=F079B6505D96 SIGN2="00DE 1CCD 0191 54C6 2888 1026 A551 0C00 5C0F C8A1 6AE6 CC2B 9CCA DD04 5870") ansoftd=( SIGN="0051 667C B2D2 2062 332E 3BF5 6F64 F100 FFCD 5BA5 85CF DADD 6490 FFAE C031" SIGN2="007A CE07 9AA8 AD74 40BF 81E2 2C32 6600 F45F 096C 5E0F CB45 D4BB 78F6 E92B") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT emit_solve ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=7C14774A1069 SIGN2="0086 6B73 C763 91E7 D8A6 5FA1 9BE2 7F00 9FF5 9ABD EC63 8FF3 A49F 1C01 8A8D") ansoftd=( SIGN="005E 731E 8D0C 3191 91EE 8742 2C74 AD00 8222 F21E D3F1 7DC2 1A55 E36C E819" SIGN2="00DF 8DB2 83E1 0FD3 4995 4E85 BC35 1700 0C29 7874 CA6B F5E2 F2EB 6C7F 67D9") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT ensemble_25_sim ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=CDB64874E0ED SIGN2="00CB 87E4 A30C 7437 1D81 EACF 57C7 0500 2F08 2EA3 96FC 3B03 4B15 A52E 37E2") ansoftd=( SIGN="0019 26B6 B8D1 38EF 7306 E843 3E4C 6100 BCFD 8854 EF24 F166 BF4D 608A 6AC9" SIGN2="00B5 2C17 A046 F26D FE2D 35F5 6827 0F00 7855 B045 9FE4 3B1D 6E74 26C1 6C5A") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT filter_synthesis ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=A53C48DEC1A8 SIGN2="003D 5912 9D75 1FB3 AF70 E46F 22AE 3500 CF90 7AEC 74AF 90D3 E437 8CA7 1F87") ansoftd=( SIGN="0036 8705 E9A8 E46C BFE8 2F86 E94C EF00 AA9B 84EA C6C5 EF37 D368 4DF9 237D" SIGN2="0078 C7F1 8CAE 892C 7190 8F95 0F4B C800 FA5D 1031 1599 E4B7 9CD6 BB7B 4FBC") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT hfss_solve ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=2F6EC8104969 SIGN2="002B FBED D32C AE7B A600 CC0C C5DF 1800 0D8F 7988 B0F5 51E4 FC39 778D 86BD") ansoftd=( SIGN="00D0 A571 92F7 083D 70E0 7709 792B 8300 C558 F144 A47D 231F 708C 62AE AB52" SIGN2="00E7 9B70 1000 5A0B 2CE2 A21D 12B6 2400 488C FA37 2693 9AB3 2789 9715 71FA") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT hfss_transient_solve ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=AA96691876A2 SIGN2="0072 E9F6 3D99 B8F3 C042 29C3 040D EF00 5AC2 3B8B 1871 8B0A 67AD 3497 2FCF") ansoftd=( SIGN="0036 F589 8BE5 09C1 9F03 CA81 7EC9 9700 E7CC EB4C A538 ED77 15AD 74B5 E8CE" SIGN2="00CA 2C8D 89C4 7984 4694 AD18 7535 DD00 79F4 5222 14AB 813E 32BD ED99 64A9") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT hfsshpc ansyslmd 9999.9999 26-aug-2019 192 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=00B347D7E8E8 SIGN2="00BF F4EF 62FF 4DC1 31F1 B937 9D0A 5200 5895 3FEE 356A BA07 C8FE 203F 4EAC") ansoftd=( SIGN="0064 1E14 9EE0 48B9 70B2 2D4E 5F98 7800 B84E 3843 03EF 3846 3884 8B8C F74D" SIGN2="0059 DDC4 8787 750B BF49 2276 4CD1 8300 E1AD 379C 33DD A4F5 C46B 2CA9 F70B") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT hfsssbr_solve ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=6AC097AD5CF4 SIGN2="00B1 F012 4948 14C6 FAB6 2B5C 5463 8200 49D0 0898 7DB2 ED38 6967 15FE E9E2") ansoftd=( SIGN="009B 5C84 24C9 54C2 645B 9262 AFE1 4E00 0F90 4BDA EB03 22C0 7BA7 3BD5 37AD" SIGN2="00BF CBD0 272C BE88 FB8D E3A9 840D EB00 F412 1A70 F7EF 244F A64F A780 CAE0") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT nexxim_ami ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=C2BAE14662E5 SIGN2="00E6 8A53 9D7A 5A37 41E2 D629 8881 E400 2EA2 8B20 58A9 58D6 9268 985C 5CEC") ansoftd=( SIGN="002D FCD2 399F C51A 2D8A 2820 AC5E 6800 2D5B B017 F94C E1D5 AF34 3B11 C8C7" SIGN2="0083 CB05 AA01 0559 1376 DF7F 8386 B800 E5AE 42AB 4D80 4FAB C64F 78DB 6F26") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT nexxim_dc ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=B584629D9034 SIGN2="0060 B60E BD4E BFED 295B E7A0 59A0 DE00 5D13 3A84 31F0 355C BC56 9514 7370") ansoftd=( SIGN="00D8 0D4D CFB3 50D8 3685 1516 5267 D500 E13C 5260 0389 4F11 2B1D 0E22 D1DB" SIGN2="006B 9078 30F6 4267 B1BB 3C64 2CD3 6B00 F407 0AE5 5E9B DB83 DDC0 33B6 1197") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT nexxim_eye ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=FE022B7664A5 SIGN2="0006 FCE5 5557 C7A0 3D92 689A 04DA 5E00 724D 20E0 0725 5448 A44D E066 4A16") ansoftd=( SIGN="002B 0081 5A8A 672D C3CC 0BF5 746B 6700 E85C 43F9 3F44 350E E89D 87D8 85BF" SIGN2="00F8 0035 E8AC 55B2 65F7 BC5D A132 4F00 BF96 AAD8 BD15 7989 A472 E428 E533") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT nexxim_hb ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=0F1C21C74117 SIGN2="00D2 14C1 3631 D726 8B09 3F49 6553 2D00 57D3 F188 942C BC92 A7CB 9E31 3E21") ansoftd=( SIGN="004D 557B A56B 4ED6 AA57 C4A4 1B17 BB00 42EB 24E2 E1BE F6EB A3F6 4F56 43AE" SIGN2="0029 FC16 144D BB97 0B28 ABCB 525B 2F00 112E 5C3A 2283 09E9 F7B5 E267 A159") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT nexxim_netlist ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=7E7CF6A29006 SIGN2="0024 3BF6 3B7A 8416 6F53 76F7 147C BC00 29F0 8876 F67B 7D1B 668A DE17 00C1") ansoftd=( SIGN="00E1 B8FD C7B6 9DD5 9F48 ED83 710E F000 B61F F99B C7B3 9776 BD61 4448 9D35" SIGN2="00AB 54BD 3081 7473 3EDF D8EB B7F0 A600 2BF9 0A4C B86A D7EB 513C 407C A992") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT nexxim_osc ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=C187BB7E221E SIGN2="009E 3EF0 4205 C948 33F9 E010 0E10 AD00 9131 5CB1 8063 4EA4 2582 59DE 9439") ansoftd=( SIGN="00E4 7182 0D7E 6D95 CF7D EF07 D1B9 B200 5E57 8C82 2325 813F 578B 2970 CA1C" SIGN2="00D7 EB8F BFAD 0F13 E543 F032 9C6C BF00 A2CC 7995 7EEE ED82 E352 01A1 1041") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT nexxim_tran ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=880389C81009 SIGN2="00A2 EDC4 E280 63DE FCD1 1CE7 FF46 CF00 F21C BCE2 79C6 6EED B15B CD1B 5F60") ansoftd=( SIGN="0058 D6B8 CA95 347A D73D 3078 8312 9900 B7D8 E5AC 17B4 F27C 2630 73AC 3AC9" SIGN2="0087 5708 75BF 2B07 35FA C7F6 E681 3E00 7051 5D35 44D8 DDC1 3568 2AC8 CADD") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT nexxim_tvnoise ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=60B8881B6D11 SIGN2="0058 D539 5944 C426 0A93 B189 93EB E100 9F21 D033 4460 F6B4 3ED2 418D C455") ansoftd=( SIGN="0037 669D 3022 D815 15AB 3946 4A63 D000 20CF 02DF CE0E 7C77 0AEB B2B9 053F" SIGN2="0037 F11F C148 9697 61E2 05C7 7E16 7700 3AAA C424 8148 C3A6 344F 47A1 680C") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT optimetrics ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=E231D9FD978F SIGN2="0018 E68A E07E E82E 41B3 56C6 2725 9800 6303 F564 4066 7139 2B43 4C81 12FE") ansoftd=( SIGN="0094 5A35 0B40 D5F3 82DC A5E1 E8ED F500 8AEB 10D8 377F ADFA 15E5 AF33 D57A" SIGN2="004E 1ACB 0FF8 66E0 406D 8E6F 9467 B600 965E 39FB 6D05 3392 3E5B 5F52 1712") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT savant_legacy_gui ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=7AA392CE3A7F SIGN2="004D D343 E20E E893 1BE6 6129 532C DA00 D28E FD8B 0FEF 3597 724D D018 60F1") ansoftd=( SIGN="005E 9F51 7028 85A0 E2FD 2254 24B5 4C00 71C7 086B 69E9 BEC2 96E4 515C 4E21" SIGN2="0072 0FC1 AD99 5507 DBA3 9ACF A0C0 C100 1CD2 5322 E338 C25C 1890 15FA 9260") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT si2d_solve ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=C4A84C94FB12 SIGN2="00A3 DFD2 921F A951 F6CC 4383 C647 FB00 2046 7FBE 062D E197 725C B24D 1EBA") ansoftd=( SIGN="00C2 58E6 A7DF 969E B6EC 28E7 9A99 4500 3A7E 50B8 E94A 81D1 419C 0847 ECCE" SIGN2="007C 6EA8 370E 0B59 4022 121A 0AC9 6000 6EEE 0E79 C42A 87CF DAAD AFB8 DDB2") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT si3d_solve ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=EBEE45140B99 SIGN2="0040 E90B CCA2 7B12 3D25 929D 20C6 7C00 39C3 30A1 0681 0126 96AC 0496 A1FC") ansoftd=( SIGN="00CC AB69 60B8 07E1 11AA FE8A 91B8 B500 0AF3 D21D 85D1 432C 4D11 370D B433" SIGN2="0029 EF36 9EC5 D980 76B5 9759 28C2 9A00 CFF9 5AF2 0625 A1FF 91AC E69A B8E1") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT simplorer_gui ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=E6535C6E5334 SIGN2="00F1 B703 6D0C 15ED F550 3697 C8F9 C900 A1A4 D2B3 2B36 6EB4 1972 EEB6 EA2C") ansoftd=( SIGN="002D 8D0D 4BC1 DF07 6908 65A9 494A 7B00 E59D D15F A3AA C19A 3251 E812 D0C8" SIGN2="003B 4E71 AF4F 6DFF B64C EE11 AA7F 6A00 B5C2 A6C1 D3D4 0BEE A112 D888 BDEE") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT siwave_gui ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=32214D774F39 SIGN2="00E7 C724 F1FF 3715 2B85 9D4D C55F 3D00 FDE1 FDAC 048F 6517 11BB 04DE 1747") ansoftd=( SIGN="00E9 73FB 7D2A C46A A60D B7DC CEEC E900 1CFC B2EB A1D5 52F6 9003 F597 A8A9" SIGN2="0091 33ED DAE0 D51D 96F8 E85F 7773 0800 AFFB 2E46 C279 9DE3 7B0F 597F 327F") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT siwave_level1 ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=0DFD0B5214D4 SIGN2="0086 8D70 6A58 6A4C 631A 6F78 906A FD00 05CC C7CF 1FF1 9CA3 294A 1DB6 CA95") ansoftd=( SIGN="00B8 C302 5CB1 B6E0 7647 7596 A4AA 9A00 8CA1 914F 83C8 EF39 B54C D568 BD0A" SIGN2="005E B80D 6F2B 9454 3628 FC4C 93C5 4700 BCCD CF15 89B7 3924 7875 5867 24BF") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT siwave_level2 ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=DD81F646F025 SIGN2="005D 0252 282F F097 EFA3 6DFD 39F5 DE00 F71C 0704 9732 CB0E BABF 987A 107B") ansoftd=( SIGN="0053 5D0E 6CE9 FD58 E42F EA3E 6B8C 8800 7C60 1277 7AFC 9F0F 05DC 7E64 A991" SIGN2="001C 5D38 A6DA 2E97 39EA 9603 89C4 7E00 0A79 9DD1 1339 321B 373F 3C02 28EA") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT siwave_level3 ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=ABD7F1525EED SIGN2="0047 6A44 3604 6F19 5F4C 4D11 346D 8600 8242 140F 22DF 0FC9 7E02 AF23 106B") ansoftd=( SIGN="00A3 384C 2397 EFC1 696C 4EEE CCA8 C700 EA01 3D2E 1D19 C3A9 8980 70A5 602D" SIGN2="0034 E2C8 CDBB FAE5 56C8 09EE ECE4 1E00 AC9E 14F8 C2B9 3CF5 7E25 BC70 71DE") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT symphony_dt_sim ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=F68EAC5715BA SIGN2="00DD 91FB 87E3 EC27 B961 0E73 D90E 5900 E3BE 12BA 68FF 4585 150E C836 7FD8") ansoftd=( SIGN="00DA F6CD 02E7 3C76 0CCA 7329 33D7 6700 60C1 A60A B71D 0C33 F87B AC80 C68C" SIGN2="004C 096E 5263 B1E9 12A0 F0EC 2052 B500 3338 80F7 71B4 8AB7 969B 75E5 759A") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT symphony_fd_sim ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=E396FA965F7A SIGN2="00AD 604C 7FF2 5445 52CE 8974 BF9C D300 50CF 8E9E D73A E47D 3D8E 7199 E8E7") ansoftd=( SIGN="00E8 DE35 5EFE 1D1E FB82 C319 7C56 8800 6F7D 6E66 2A74 66DD 7149 FA47 2F5B" SIGN2="001F 625E BA0F 54A9 2974 8C23 B385 5200 FC50 30EF 554E 06EE F1E7 F96A BB8F") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT xlate_catia4 ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=9B8DB4EE2A61 SIGN2="0037 9590 8F7A DF2E 1207 1262 79E8 EE00 F575 FD73 B532 B23E 1B0E A200 83A7") ansoftd=( SIGN="0051 4AFC 1745 3C43 1BD5 EFE9 7C9E A700 E858 C275 6E9A C9B1 2155 C088 3DB6" SIGN2="00A8 06BB 6F4E 6C86 675A 3B2D 420F EE00 CF86 F9B8 B702 616D 3C79 3E0A CDC4") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT xlate_catia5 ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=57FC8D60DFE8 SIGN2="0052 906A EEAD E20E F575 C564 8983 AB00 B233 2D5D D915 A051 71A8 6DA0 FACD") ansoftd=( SIGN="0015 A215 2ED6 4DC4 C7A0 501B B01A 4700 47BB 97BA 56E6 539E 79AD EFEF 5428" SIGN2="00A8 F545 10A7 E632 B9DD 1B4A D5DF A500 0B3E E08E D77D 6B27 B992 DAD9 3396") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT xlate_iges ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=4F1DFEB24D37 SIGN2="005F AF72 CEAC 939E 99AC 3311 6E17 4800 A710 9365 34D3 F219 FEFD 440D B14C") ansoftd=( SIGN="0042 D5C1 8664 CE2B 0BCE CF3E 7274 9300 E660 3345 6571 EA9C B622 715E D7E2" SIGN2="0067 2CB9 17C6 E12B CA38 B080 6E2F 3600 A0ED C792 923A 2736 80A6 CDD5 DC50") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT xlate_inventor ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=D39850EAACA8 SIGN2="0047 0B6E D7CA 0765 58A7 663E 810C 4D00 4CAA 574B B588 9FEA 89D1 3C67 B991") ansoftd=( SIGN="001A 0B2B 8E56 A355 294B 6583 A2E6 4800 2594 E9E1 9580 AA0D DEC2 C5E6 C775" SIGN2="0097 EB0D 700D 3797 89D6 E039 F89A AB00 9965 DF5E 91A6 DC91 09AD C884 CDD5") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT xlate_parasolid ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=CFA9C3BAE2DA SIGN2="0045 EBAD 5EA2 04F1 FED5 4398 F6FF 3800 5475 CCA8 1CAA D561 4FBC 4AFC 76D6") ansoftd=( SIGN="0015 AF60 329D 4A04 A689 DBC1 E345 3600 FCD8 ED76 BAAB D0D6 F28C 796F 7106" SIGN2="005A 9CA8 2214 9EA8 F886 F85C B746 F000 13A6 F4C5 E863 4FEE AF51 2003 136D") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT xlate_proe ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=9E759A835B24 SIGN2="00B9 2469 7E3D 1888 F39B 6832 5459 4600 EE65 7D08 8350 4F71 D0BD 9B1D 63C9") ansoftd=( SIGN="0032 CBFA 65E3 BB77 EB61 AB30 380B 1700 930C 1199 EEEC 10EE 0072 5325 9DE1" SIGN2="004D 7705 164F 26A6 387D EE28 5A20 4700 7C4B 0AFA FDC4 3AC4 1B47 9126 C818") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT xlate_solidworks ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=DF5EC554EEDF SIGN2="006D F166 49AE 3D35 5786 4499 945A EF00 FC20 C1E8 CA62 3DAD DFEC F495 FBC1") ansoftd=( SIGN="0020 ED9B 14AB 0D4E DD62 7D6C 1DD1 5E00 6466 4DB9 7352 3840 9D1F 2040 00B8" SIGN2="000C 5D03 2273 F920 8EBA 768B D1D4 DF00 F483 5AAF 90F5 EAA7 1C58 6E0B 954A") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT xlate_step ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=2A3BF47DB682 SIGN2="0044 CF07 62F4 4425 DD0F 332C 2932 2400 E3B2 AFC1 2776 118C 7EE4 8DFC 52CC") ansoftd=( SIGN="00FA 6505 F173 5072 FDA9 E4EC E357 A400 504F 38A2 8BE0 9CBA 4AEA 0029 AFF8" SIGN2="004F E633 C83D E50B 6D14 AA01 2787 3A00 B139 C014 FE6C 04EC 5CA6 DA89 9ADF") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT xlate_unigraphics ansyslmd 9999.9999 26-aug-2019 10 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=9F60C71C39BB SIGN2="006A 0ECB 3C74 A326 483A 5DB5 9ACE 3100 BA4F 20AA 106A EC37 98B0 8E56 8E9B") ansoftd=( SIGN="005A A932 1235 F6B9 BCDC FC1F FF5D 9500 124E 7DDA DAE6 6C67 08DF 72BE C568" SIGN2="0061 897F E184 171B 64CE 418D 7D19 8000 BF00 2129 D304 C9FD 3571 BA6B 453C") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT m2dfs_qs_solve ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=1BBB22105DA3 SIGN2="00C6 3609 1BE8 2370 E828 E675 EB5C E700 EEB8 7067 15BC 661E 7E11 93C1 A882") ansoftd=( SIGN="0006 825F 6902 C7DE AD25 4F41 FD30 0D00 1F97 19D4 9ADB 6213 6C88 B5C0 4773" SIGN2="007F EB7F 1221 CC41 6A74 5C07 FAC9 0300 524C 6C1B 043B 5A77 95DC 9B0E 5AFD") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT m2dfs_solve ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=3E7011496ACD SIGN2="0021 D5E3 5F7E 36CE 0210 12FD 0D8C FE00 DD5E AE89 8E7E 61CF F23E 04A8 A1F3") ansoftd=( SIGN="00D8 4ACD 32EC C2C9 FB62 DBB9 7B5E BB00 8F4F 9902 38FA 5E43 7450 85C6 35A4" SIGN2="00CD D6C2 338A 72E6 6DB0 D251 FE72 D800 8C28 6836 F2CC 1815 BE89 3B3B CC2A") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT m3dfs_qs_solve ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=BDDB984F5900 SIGN2="0040 FB50 95EA FB51 FFD2 E525 F2FB 6200 FEC9 38D6 472E 326C A713 8E5D B693") ansoftd=( SIGN="001D 87ED 2F80 5E4A B3A8 2C11 8E61 C600 27B4 2A44 70BC 48A9 4EA4 3D68 38CA" SIGN2="00A1 C4D5 DE76 CB85 CC3E 7AD6 7C73 D800 4E9F 406F E69E EF05 F35D BB00 4A98") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT m3dfs_solve ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=B50069432744 SIGN2="0016 BA92 F13F 868C DCE8 30C2 0213 7900 B297 6216 3884 96D5 F45B 8336 68CC") ansoftd=( SIGN="00E4 21D6 5F19 2CBC 286A 7325 9096 7500 5171 218A D537 83C5 0471 E6B6 27DC" SIGN2="0028 7981 599F 5CEA 10FB 3DD7 B937 E200 C7EB 0D73 B04E B8B2 DAA9 7582 4738") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT maxwlspc ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=7F74666402D5 SIGN2="00BE 689D CA5A 8678 8C80 9645 79CB 1400 A788 2801 AAD1 8812 3852 8551 3948") ansoftd=( SIGN="00FE 2C01 DB38 5143 C55D BA2E FE32 8A00 EBF7 6708 8394 9AE2 5460 79CF A06E" SIGN2="0081 1C2F 66F2 34EB 6A93 DC62 907E D700 AA9C E5A2 D057 2D8D B06E F9B2 B6E5") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT pemag ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=C8D05D864265 SIGN2="00CD 110D C709 21F7 3B43 09AE 04B8 EF00 176F 1D34 B43E 5280 A030 D0EB 3AB7") ansoftd=( SIGN="003E 7A3C 7E9C 9A8B 3DD4 4EF8 8646 C500 69C6 DAF5 D27C C1B0 500C 5D25 F87E" SIGN2="00A4 ED0B C5EB 60E8 92A0 B6C0 FB83 0500 59ED B9AE EF7B 2C3E EB23 E277 18C2") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT pexprt ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=F1FD2D3DC4C2 SIGN2="006A EBAE 7210 CAC4 5496 0EF2 18E3 2000 82C1 AA39 0A35 DD42 198F 1C4E 3E49") ansoftd=( SIGN="00CC 3D50 C048 4B39 5B70 2FC0 2C01 E700 BABD 69CA 2748 5EC5 9636 662A A4E4" SIGN2="00D9 D913 367B C50D 2E28 588E 7E7D 0400 BF58 6AA9 B49C D028 1876 CC01 6190") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT rmxprt_bcm ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=991F357FDB8A SIGN2="000C 5B95 A173 E2DE 65A2 6E5B 3752 5B00 4717 8869 EC8B F04E F51F AD28 854E") ansoftd=( SIGN="00FE 8EEC F0DD A09D 1569 D8D6 49D5 8E00 7104 ED7A C91B A8CF 03D2 14F8 3623" SIGN2="00A0 F7D9 E4EB B856 F167 B541 D236 2400 6ABA F578 EFCC D62C E479 0225 4B59") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT rmxprt_ecm ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=073F04A68B80 SIGN2="00EF 4EFF B255 63D9 54C0 4C00 C469 0700 2098 E3FC 0B3F 91F7 0D27 E8AA 9654") ansoftd=( SIGN="0030 4F34 B575 8E46 421A 26CE 8E54 6D00 23E4 7377 6AB7 8689 E8DE 3B61 3413" SIGN2="0049 ADC9 5654 8974 1612 E21D 2C53 3800 A38E C10B B0A3 0E02 F525 B08B 251F") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT rmxprt_im ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=F11752806452 SIGN2="0070 B956 0448 6F38 2AD4 1160 8D3C B100 4B8E 1F38 D787 EC43 0F7D C3CC 1926") ansoftd=( SIGN="0045 D49E 2380 211A B7A4 2C83 8C5C 6200 9906 3AFB 8439 73A3 41B3 B4A3 50A0" SIGN2="0009 00C5 F28F A21C 09FD 70F2 DC7E 0F00 936B F6E4 B649 458A 94DE D1FE 9F16") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT rmxprt_sym ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=80FDC04B06B9 SIGN2="008C 74C3 7FDC ECF3 87CC C962 DB4B F800 1B29 862E B9C5 71BD 2076 60CD 9229") ansoftd=( SIGN="0004 2C3B B49E 5734 89EF C6F4 F169 7400 0FE3 3A7B 3414 CB2A 7DFC 68BF 4BFF" SIGN2="001F EC9D 962B D1A6 7E67 0B3A 861D 6C00 24C4 A294 C672 AE04 53A4 0E7B 371E") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT simplorer_advanced ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=4168BB0925DB SIGN2="001F 55B5 E8E1 6457 B4F4 F85C 2893 4100 713F FA93 FEF3 CB25 6690 978E 0222") ansoftd=( SIGN="0060 32AC 07FB 8BE8 D737 ED6B C15E 4100 B635 4493 E123 5E81 2662 108A 3A1A" SIGN2="00A0 5802 A2E3 98AE FE98 D511 C8A9 B000 A68E 64A3 5964 A616 CEA0 3723 8EC6") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT simplorer_control ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=32F4C82A5340 SIGN2="00BC 84C6 49A1 884D 4921 B03E B3C6 DE00 C675 4E21 C985 1BF3 182F 2FF6 E6F6") ansoftd=( SIGN="00F8 7059 4AF0 CFA2 F0C3 FBA1 B6D0 AA00 3EDB A385 7154 5320 BF0D DFC1 5B10" SIGN2="0008 3CA6 630B 6D73 1BCC A93A 125E A100 CF44 6764 305B D113 1B10 F85A F602") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT simplorer_CProgrInterface ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=D38702235886 SIGN2="0014 BA42 2518 1C6D 731F F5A8 72EC 3600 A583 2EAE A490 5665 CCB4 2B6D 464F") ansoftd=( SIGN="009B 618A 4F7A 4102 39D0 6538 B3FE E700 5E62 7C2D 506E 7540 4945 7CF1 7451" SIGN2="0004 4FBF FCE3 8F85 04B5 E919 F8DC 2E00 5AD3 654C 5D91 7F63 DA29 5D75 BEF4") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT simplorer_LibSMPS ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=A4D94B46DA49 SIGN2="002C 3B2E 7287 1895 C66D 0DB5 890B EE00 11BF 6C7A 518C 01EA B1E5 4AE0 1B8F") ansoftd=( SIGN="000E 61A4 575D 0F59 4DAE 09F9 38D4 4800 07E4 4C1C E9BA A075 0F99 86B1 EACC" SIGN2="0043 5D46 59B7 28CE 2AB9 11DF 6520 3F00 8F5F D2D5 349D 0907 424E AFAA E20E") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT simplorer_model_export ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=B4EFFB5F8A81 SIGN2="002C 86E4 57AF 00B4 841B CD98 9A0E C200 7EF7 6167 A4B9 AF02 BA1A DF80 BF03") ansoftd=( SIGN="0031 E7A3 5FD2 3115 F37E FC9C DBB7 3E00 4074 0C82 CF2E 0E2E 81AE 4A04 7F8B" SIGN2="00E4 6FC4 8533 1326 9DCE 5529 0453 5A00 0270 46EE 8F8C 2B5D 242A 54AB 36C4") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT simplorer_modelica ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=F7D8CC791F70 SIGN2="009A 6B67 E5F1 6474 8A2C A3E8 D3CA 3B00 ED74 8752 4038 CF0D FF22 0B9D C638") ansoftd=( SIGN="000B D0D4 C18B 1FCF 8F8A 4E68 59F3 B600 17A2 BBA9 C473 DC96 E2DC 6DDA 3663" SIGN2="00BC 40DF 09B4 F0BA 8393 3909 4EFB BF00 F836 48B4 41CF 51E5 28B3 B8BC F4C0") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT simplorer_sim ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=C5223E9D07BE SIGN2="0019 5E68 DD09 ED94 0791 D681 3011 6600 6AA2 4413 4E6D 0134 6B40 7571 25BD") ansoftd=( SIGN="00ED CD64 85F0 1D00 DD78 92D3 9E8B C700 821D BB33 6C6A 76EE 56AF 4EAA 6D7D" SIGN2="0041 4A6A BDC3 8B93 AE33 E195 1B3C 6A00 F2A7 EBEC 2DF2 9715 DAA3 B243 BB73") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT simplorer_sim_entry ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=964C554049CA SIGN2="0075 46D1 1E4A D7FE E09F 78BB 8F1A 9C00 B671 AEEF 5F31 8A6E CA13 8CAC 86F6") ansoftd=( SIGN="009C 0C2C 7AC6 6710 D41C 3246 8B58 9B00 9757 8F06 774D EF16 8176 9282 7F4A" SIGN2="00A4 E840 F4CE 80C0 E45B 91ED 5579 0000 26DF 6814 2AF1 CA39 4313 D809 CA96") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT simplorer_vhdlams ansyslmd 9999.9999 26-aug-2019 5 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 AUTH={ ansyslmd=( LK=F204FBDF3484 SIGN2="0032 674B 99AC A438 9CE0 C4CF 6536 8A00 B6A8 8137 40A8 E202 5898 DFEC 126B") ansoftd=( SIGN="00A7 FBC4 7BD9 C29B BFA0 A640 3495 2200 EE81 BBE7 C258 16CD 9529 DA47 9426" SIGN2="002F EAED 5AFD 21D2 EC64 C13B 4BA7 8800 E61D CE25 82A6 872F 3D1E B81E 5C6C") } 9:23:55 (ansyslmd) Invalid license key (inconsistent authentication code) 9:23:55 (ansyslmd) ==>INCREMENT aa_r_hpc ansyslmd 9999.9999 26-aug-2019 32 22C3620B40A6 VENDOR_STRING=customer:01116749 SUPERSEDE ISSUER=SIEBEL ISSUED=25-sep-2018 START=25-sep-2018 SIGN2="00D5 133C C623 2BA3 D639 D129 1A70 3E00 E8FD 82E0 C8C6 B58F 45A8 E072 C27A" 9:23:55 (ansyslmd) License server system started on DESKTOP-QQBF4SB 9:23:55 (ansyslmd) No features to serve, exiting 9:23:55 (ansyslmd) EXITING DUE TO SIGNAL 27 Exit reason 4 9:23:58 (lmgrd) ansyslmd exited with status 27 (No features to serve) 9:23:58 (lmgrd) ansyslmd daemon found no features. Please correct 9:23:58 (lmgrd) license file and re-start daemons. 9:23:58 (lmgrd) 9:23:58 (lmgrd) This may be due to the fact that you are using 9:23:58 (lmgrd) a different license file from the one you expect. 9:23:58 (lmgrd) Check to make sure that: 9:23:58 (lmgrd) C:Program FilesANSYS IncShared FilesLicensinglicense_filesansyslmd.lic 9:23:58 (lmgrd) is the license file you want to use. 9:23:58 (lmgrd) 15:23:54 (lmgrd) TIMESTAMP 11/5/2018 22:42:52 (lmgrd) TIMESTAMP 11/5/2018 22:48:51 (lmgrd)
22:48:51 (lmgrd) Please Note: 22:48:51 (lmgrd) 22:48:51 (lmgrd) This log is intended for debug purposes only. 22:48:51 (lmgrd) In order to capture accurate license 22:48:51 (lmgrd) usage data into an organized repository, 22:48:51 (lmgrd) please enable report logging. Use Flexera Software LLC's 22:48:51 (lmgrd) software license administration solution, 22:48:51 (lmgrd) FlexNet Manager, to readily gain visibility 22:48:51 (lmgrd) into license usage data and to create 22:48:51 (lmgrd) insightful reports on critical information like 22:48:51 (lmgrd) license availability and usage. FlexNet Manager 22:48:51 (lmgrd) can be fully automated to run these reports on 22:48:51 (lmgrd) schedule and can be used to track license 22:48:51 (lmgrd) servers and usage across a heterogeneous 22:48:51 (lmgrd) network of servers including Windows NT, Linux 22:48:51 (lmgrd) and UNIX. Contact Flexera Software LLC at 22:48:51 (lmgrd) www.flexerasoftware.com for more details on how to 22:48:51 (lmgrd) obtain an evaluation copy of FlexNet Manager 22:48:51 (lmgrd) for your enterprise. 22:48:51 (lmgrd) 22:48:51 (lmgrd)
22:48:51 (lmgrd) 22:48:51 (lmgrd) 22:48:51 (lmgrd) Server's System Date and Time: Mon Nov 05 2018 22:48:51 Hora est?ndar central (M?xico) 22:48:51 (lmgrd) SLOG: Summary LOG statistics is enabled. 22:48:51 (lmgrd) Running the license server manager (lmgrd) in dedicated windows ... 22:48:51 (lmgrd) Use -z to run in foreground in this window 22:48:51 (lmgrd)
22:48:51 (lmgrd) 22:48:51 (lmgrd) 22:48:51 (lmgrd) Server's System Date and Time: Mon Nov 05 2018 22:48:51 Hora est?ndar central (M?xico) 22:48:51 (lmgrd) pid 7764 22:48:51 (lmgrd) SLOG: Summary LOG statistics is enabled. 22:49:06 (lmgrd) The TCP port number in the license, 1055, is already in use. 22:49:06 (lmgrd) Possible causes: 22:49:06 (lmgrd) 1) The license server manager (lmgrd) is already running for this license. 22:49:06 (lmgrd) 2) The OS has not "cleared" this port since lmgrd died. 22:49:06 (lmgrd) 3) Another process is using this port number (unlikely). 22:49:06 (lmgrd) Solutions: 22:49:06 (lmgrd) 1) Make sure lmgrd and all vendor daemons for this 22:49:06 (lmgrd) license are not running. 22:49:06 (lmgrd) 2) You may have to wait for the OS to clear this port. 22:49:06 (lmgrd) Retrying for about 5 more minutes 22:49:24 (lmgrd) Still trying... 22:49:42 (lmgrd) Still trying... 22:50:00 (lmgrd) Still trying... 22:50:18 (lmgrd) Still trying... 22:50
6 (lmgrd) Still trying... 22:50:54 (lmgrd) Still trying... 22:51:12 (lmgrd) Still trying... 22:51
0 (lmgrd) Still trying... 22:51:48 (lmgrd) Still trying... 22:52:06 (lmgrd) Still trying... 22:52:24 (lmgrd) Still trying... 22:52
9 (lmgrd) Failed to open the TCP port number in the license. 11:19:43 (lmgrd) TIMESTAMP 11/6/2018 12:28:47 (lmgrd)
12:28:47 (lmgrd) Please Note: 12:28:47 (lmgrd) 12:28:47 (lmgrd) This log is intended for debug purposes only. 12:28:47 (lmgrd) In order to capture accurate license 12:28:47 (lmgrd) usage data into an organized repository, 12:28:47 (lmgrd) please enable report logging. Use Flexera Software LLC's 12:28:47 (lmgrd) software license administration solution, 12:28:47 (lmgrd) FlexNet Manager, to readily gain visibility 12:28:47 (lmgrd) into license usage data and to create 12:28:47 (lmgrd) insightful reports on critical information like 12:28:47 (lmgrd) license availability and usage. FlexNet Manager 12:28:47 (lmgrd) can be fully automated to run these reports on 12:28:47 (lmgrd) schedule and can be used to track license 12:28:47 (lmgrd) servers and usage across a heterogeneous 12:28:47 (lmgrd) network of servers including Windows NT, Linux 12:28:47 (lmgrd) and UNIX. Contact Flexera Software LLC at 12:28:47 (lmgrd) www.flexerasoftware.com for more details on how to 12:28:47 (lmgrd) obtain an evaluation copy of FlexNet Manager 12:28:47 (lmgrd) for your enterprise. 12:28:47 (lmgrd) 12:28:47 (lmgrd)
12:28:47 (lmgrd) 12:28:47 (lmgrd) 12:28:47 (lmgrd) Server's System Date and Time: Tue Nov 06 2018 12:28:47 Hora est?ndar central (M?xico) 12:28:47 (lmgrd) SLOG: Summary LOG statistics is enabled. 12:28:47 (lmgrd) Running the license server manager (lmgrd) in dedicated windows ... 12:28:47 (lmgrd) Use -z to run in foreground in this window 12:28:47 (lmgrd)
12:28:47 (lmgrd) 12:28:47 (lmgrd) 12:28:47 (lmgrd) Server's System Date and Time: Tue Nov 06 2018 12:28:47 Hora est?ndar central (M?xico) 12:28:47 (lmgrd) pid 6120 12:28:47 (lmgrd) SLOG: Summary LOG statistics is enabled. 12:29:02 (lmgrd) The TCP port number in the license, 1055, is already in use. 12:29:02 (lmgrd) Possible causes: 12:29:02 (lmgrd) 1) The license server manager (lmgrd) is already running for this license. 12:29:02 (lmgrd) 2) The OS has not "cleared" this port since lmgrd died. 12:29:02 (lmgrd) 3) Another process is using this port number (unlikely). 12:29:02 (lmgrd) Solutions: 12:29:02 (lmgrd) 1) Make sure lmgrd and all vendor daemons for this 12:29:02 (lmgrd) license are not running. 12:29:02 (lmgrd) 2) You may have to wait for the OS to clear this port. 12:29:02 (lmgrd) Retrying for about 5 more minutes 12:29:20 (lmgrd) Still trying... 12:29
8 (lmgrd) Still trying... 12:29:56 (lmgrd) Still trying... 12
0:14 (lmgrd) Still trying... 12
0
2 (lmgrd) Still trying... 12
0:50 (lmgrd) Still trying... 12
1:08 (lmgrd) Still trying... 12
1:26 (lmgrd) Still trying... 12
1:44 (lmgrd) Still trying... 12
2:02 (lmgrd) Still trying... 12
2:20 (lmgrd) Still trying... 12
2
5 (lmgrd) Failed to open the TCP port number in the license. 17:21:23 (lmgrd) TIMESTAMP 11/6/2018 23:21:26 (lmgrd) TIMESTAMP 11/6/2018 14:08:42 (lmgrd) TIMESTAMP 11/7/2018 -
November 7, 2018 at 11:37 pm
tsiriaks
Ansys EmployeeHi Najjib ,
This is the issue 'Invalid license key (inconsistent authentication code)'
Please post the screenshots of the content of your license file (the top part of it) and the 'Get System HostID Information' from the ANSYS License Management Center
Thanks,
Win
November 8, 2018 at 4:57 am
November 8, 2018 at 5:18 pm
tsiriaks
Yes, that's correct. Thank you for the screenshots.
Can you re-download the license file again (from original source that you received it). Then, before install it, open it up with a Text Editor application like Textpad or Notepad++ , then check the text encoding of the file and make sure that it's 'ANSI' . If not, please save it in ANSI format.
Also, go to C:Program FilesANSYS IncShared FilesLicensinglicense_files , then delete all files in there except the 'backup' folder.
Then install the license file using the ANSYS License Management Center. Let us know what message is shown when you are installing it.
Thanks,
Win
November 14, 2018 at 5:18 am
NajjibGuerra
SubscriberHI Win,
I have one question, what do you mean for "text encoding?", because i don´t know where is the "ANSI" you previously told me.
Have a nice day!
Thanks
Najjib Guerra
November 14, 2018 at 6:05 pm
tsiriaks
You can check this out
https://www.w3.org/International/questions/qa-what-is-encoding
There are text editor applications that can change/check the current encoding of your text file (like Textpad or Notepad++) . You can find one and make sure your license file is in ANSI format
Thanks,
Win
November 14, 2018 at 7:29 pm
NajjibGuerra
SubscriberHi Win,
So you´re telling me that the format of the license must be like: "license-ansys_hybridXXXXX.ANSI"?
Thanks, Win.
Najjib Guerra
November 14, 2018 at 7:48 pm
NajjibGuerra
SubscriberHi Win,
I think I have just installed the license file, I´ll attach a picture of the message shown, after inserting the license file, but I have another problem, that is when I try to run the License Manager, another message is shown, I´ll attach it too, so what should I do? And after these steps, I have to download the packages of the customer portal and the license file will be attached automatically? Sorry for the troubles!
Thanks,
Najjib Guerra
November 14, 2018 at 9:33 pm
tsiriaks
Text encoding has nothing to do with file extension, please refer to the link that I sent for more info.
Now for the other error message, before trying to start the License Manager, launch Windows Task Manager and make sure you manually kill those processes that are described in the error message..
Thanks,
Win
November 18, 2018 at 10:00 pm
NajjibGuerra
SubscriberHi Win,
I´m sorry for the troubles but the problem persists, the problem is in the FlexNet licensing, is this affects on the installation of ANSYS? Again I´m sorry but I can´t resolve this problem by following the instructions shown on the License Manager.Â
For the FlexNet file, I chose the license file, maybe is for that the problem I have?.
Thank you very much for your help Win.
Have a nice day!
Najjib Guerra -
November 19, 2018 at 7:07 pm
tsiriaks
Ansys EmployeeHi Najjib,
I will reach out to your ASC and we can work on this issue via your ASC. It's more efficient that way.Â
Once we figure out the issue, we can update it here so that others with similar issue can follow it.
Thanks,
Win
November 20, 2018 at 4:30 am
NajjibGuerra
SubscriberThanks Win, I´ll be waiting!
Najjib Guerra
November 21, 2018 at 5:41 pm
tsiriaks
I sent you two emails but haven't got any response.
Do you receive them ?
Thanks,
Win
November 21, 2018 at 5:50 pm
NajjibGuerra
SubscriberHi Win,
Yes, I received your e-mails, I´ve just answered.
Do you receive my e-mail?
Thanks,
NajjibÂ
August 17, 2019 at 5:59 pm
akashgp1516
Subscriber hi Najjib,
im going through the same problem with my installation.
did you find the solution with the flexnet licensing problem?
August 19, 2019 at 5:00 pm
tsiriaks
Ansys EmployeeHi akashgp1516,
If your issue is really the same thing, the resolution for Najjib was to download the ANSYS License Manager from ANSYS website and reinstall the License Manager.Â
Thanks,
Win
- The topic ‘Ansys License Managment Center Error’ is closed to new replies.
5194
1859
1387
1250
