January 13, 2025 at 3:44 pmpaul pladetSubscriber
Is it possible to run the ansys license manager on VM? I am trying to configure it and everything seems fine (LM is running), except when i try to connect a client pc to it it gives a random ip adress error and not the correct server hostname.
I have already added the correct ports in firewall and have full admin rights.
When opening the license server settings and click on test, it says that lmgrd is not running on the client.
Any idea if i am missing something?
Viewing 0 reply threads
Ansys Innovation Space
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Issue Seeing Explore
- Warning Plugin Error Geometry in Design Modeler
- SpaceClaim stops sharing topology
599
591
565
366
