October 4, 2023 at 2:00 pm
October 4, 2023 at 3:12 pm
VJ
Ansys EmployeeIn the Licensing Settings 2023R2, click Features in Use. Does this display 'disco_level1' increment? If it displays any error message, please share it in the comment.
October 5, 2023 at 7:47 am
October 5, 2023 at 6:55 pm
VJ
Ansys EmployeeThis is likely because the vendor daemon port is getting blocked.Â
On the server -Â
Please navigate to the
:\ANSYS Inc\Shared Files\Licensing\license_files Copy the ansyslmd.lic file in the location to the desktop location and add ‘PORT=1056’ in the VENDOR ansyslmd line and save it in. Then replace the old ansyslmd.lic file with the new one in the above mentioned location.
Once this is done, please restart the license manager –
- Go to start > ANSYS License Management Center
- In the ‘View Status/Start/Stop License Manager’, STOP the service and START it again.
- Ensure 1056 TCP is opened in the server side and the client machine.
Now retry the application.
November 14, 2023 at 1:43 pm
Charlie
Subscriber -
November 14, 2023 at 4:04 pm
VJ
Ansys EmployeeDoes the customer still get an error -15 code when they try to see the features in use?
November 16, 2023 at 3:46 pm
November 16, 2023 at 5:09 pm
VJ
Ansys EmployeeWe do not need 1056 port mentioned in the licensing settings. You can remove that entry. 1055 and server name alone is enough. 1056 is just a static port assignment for vendor process.Â
November 22, 2023 at 7:54 am
Charlie
SubscriberHello,
The problem is solved. Thank you for your help.
- The topic ‘Ansys license manager Error’ is closed to new replies.
5654
1885
1404
1303
