August 11, 2018 at 9:15 pm
baturayz
SubscriberHello everyone,
I am working diesel engine's cfd analyse. In Forte tutorials, chapter 11: Combustion Simulation for a Sector in IC Engine System
(ANSYS Workbench), i am doing this chapter myself, i am opening workbench>Select Forte> Edit Simulation Settings> I am writing every input as same in the tutorial> ok. But nothing happens. When i close edit simulation settings, there is error panel below you see in the pic: An unexpected erros has occured: Invalid quantity string: 0,2 mm.Â
August 13, 2018 at 3:22 pm
Forum ModeratorCan you check you've put the number in as 0.2 and not 0,2 ? ANSYS software uses a decimal point and not a comma.Â
August 16, 2018 at 6:49 pm
baturayz
SubscriberDear rwoolhou
You see that there is no 0,2 at my entry. Programme asks me 3 inputs in the picture you see:
1. Connecting rod length
2. Crank radiusÂ
3. Piston offset/wrenchÂ
And my answers are the same with tutorial:
1. 165
2. 55
3. 0
 These are tutorial values. How can it be and give error. It is interesting.
August 20, 2018 at 7:43 pm
baturayz
SubscriberThis is in Forte Tutorial: Chapter 11: Combustion Simulation for a Sector in IC Engine System
But it is giving error. Can anyone help me?
August 29, 2018 at 8:33 pm
baturayz
SubscriberCan anyone help me? I downloaded my workbench file
- The topic ‘Ansys Forte Chapter 11 String Error’ is closed to new replies.
3597
1283
1117
1068
983
