May 22, 2020 at 5:48 pm
LindaC
SubscriberHi to everybody,
I am new in Ansys. I wanted to ask two questions:
- If I chose pressure-far-field for two horizontal sides (upper and lower boundaries of the domain, in Fluent they are called free2) I cannot put Mach Number equal to zero: "Error at Node 0: Mach number at Pressure Far-Field boundary should not be set to zero.";
- Â Â Â Why I cannot put a Mach number of 0?
- If I put a very low number for Mach number I get the result in the picture attached, which is technically wrong;
- Â Â Â Do you know I get this kind of strange results?
Thank you.
Linda
Viewing 0 reply threads
- The topic ‘Ansys Fluent-Airfoil – unexpected results’ is closed to new replies.
1598
1386
1242
