March 24, 2024 at 11:21 pm
Gonzalo MartÃn Suárez
SubscriberHello. I'm experiencing an issue with Ansys Fluent. After launching Fluent from Workbench, the application opens, but I'm unable to edit anything. Then, after approximately 5 minutes, the application closes itself. I suspect it may be a licensing problem. How can I resolve this?
March 25, 2024 at 11:21 am
Forum ModeratorPlease post an image of what you're seeing. Is there anything in the .trn file? Can you launch Fluent from the Start menu?
March 25, 2024 at 12:23 pm
SubscriberAfter Fluent opens I can see this...Â
Then, after 5 to 10 minutes the following pop up appears:Â
Running the Fluent from the start Menu, after some minutes the following pop up appears:
About the .trn file, where I can find it? If I open the Fluent from the Start Menu, I´m experiencing the same problem.
Thanks in advance!
March 25, 2024 at 12:29 pm
March 25, 2024 at 1:58 pm
Forum ModeratorCan you check the number of gpu's setting in the Launcher is set as zero. Student doesn't have any gpu acceleration licence, nor will most academic licences.Â
March 25, 2024 at 2:05 pm
March 25, 2024 at 2:10 pm
Forum ModeratorAnd on the Launcher "Home" tab?
March 25, 2024 at 2:13 pm
March 25, 2024 at 6:17 pm
George Karnos
Ansys EmployeeHello,
Is this on a laptop?
If so, there may be multiple Graphics cards... Intel and Nvidia.
Verify that the Nvidia is the primary Graphics card being used for Apllications:
/knowledge/forums/topic/what-can-be-done-if-the-graphics-window-remains-black-graphics-card-is-nvidia/ -
March 25, 2024 at 7:17 pm
SubscriberYes, it is a laptop. This laptop has inlet integrated video card. But I ran the Ansys Discovery Compatibility Utility and the test was OK.
March 25, 2024 at 7:56 pm
George Karnos
Ansys EmployeeHave you installed the latest driver?
March 25, 2024 at 8:30 pm
SubscriberThe lastest Ansys Discovery Compatibility Utility or any other driver?Â
March 26, 2024 at 12:29 pm
George Karnos
Ansys EmployeeThe latest Intel Driver for your graphics card.
April 11, 2024 at 10:02 pm
SubscriberAfter updating the Intel Drivers the problem still there. Can I do anything else?
- The topic ‘Ansys Fluent’ is closed to new replies.
5674
1890
1419
