November 6, 2018 at 7:56 pm
jwong17
SubscriberHello,
My ANSYS EM Suite 19.2 was working fine the other day but when I went to open the application today it produced a pop up box with several icense errors:
Failed to check out license 'hfss_desktop'.
License server does not support this license (FLEXlm Error -18)
Failed to check out license 'designer_desktop'.
Failed to check out license 'q3d_desktop'.
Failed to check out license 'maxwell_desktop'.
Failed to check out license 'simplorer_desktop'.
Failed to check out license 'electronics_desktop'.
System clock has been set back (FLEXlm Error -88)
I tried reading through the ANSYSLicensingInstructionsAndTroubleshooting.pdf but I am unable to perform the solutions provided.
Any help would be appreciated.
November 6, 2018 at 8:49 pm
tsiriaks
Ansys EmployeeHi jwong17,
Can you check with the license server admin to see if at least one of these licenses still valid on the license server ?
Thanks,
Win
November 6, 2018 at 8:54 pm
jwong17
SubscriberSo right now I am using my license on my personal laptop.
I was able to get a trial version of the software and when I asked if I could just put the license on my personal computer I was told it would be fine.
It was working fine before today but for whatever reason this license error appeared.
November 6, 2018 at 10:58 pm
tsiriaks
Sorry, I failed to notice the last error (FLEXLM Error -88).
For this issue, please refer to this thread /forum/forums/topic/license-manager-error-aa_t_i/
Thanks,
Win
November 6, 2018 at 11:05 pm
jwong17
SubscriberIs there a way to just generate a new license instead of changing my computer's time to the future? (I think that if I do this it will mess up my other applications on my computer.)
The reason I ask is that I have 5 licenses with my trial and I am the only one using this software. If the answer is yes should I get in touch with my point of contact that helped me with getting the license first.
November 6, 2018 at 11:19 pm
November 7, 2018 at 12:06 am
tsiriaks
Ansys EmployeeDon't need to run that tools. That tools is used only for Mechanical and Fluids products.
The issue is not about the license file and you should not change your computer time to future. You should search your systems for the file(s) with future date. This is a mechanism in FlexNet licensing to check for the 'current date' and to prevent people from changing their own computer date back to the past to make licenses valid. The reason that it doesn't check the current time/date on internet is because FlexNet licensing can be used without computer accessing internet. You can also find this same issue for other software using FlexNet for their floating license technology.
Thanks,
Win
- The topic ‘ANSYS EM Suite 19.2 License Error’ is closed to new replies.
4452
1494
1376
1209
