March 15, 2018 at 2:58 pm
Eric
SubscriberHello,
I'm new to ANSYS and have recently installed Ansys Student 19.0 (Win10 64bit). I would like to open my SolidWorks files in Ansys. When I try to do so there are a lot of error messages popping up. It doesent matter if I take a *.step-, *.igs-, or a *,sldprt-file to open. Please have a look at the attachements for more details.
Thanks for any help.
Eric
March 15, 2018 at 7:42 pm
vganore
Ansys EmployeeIt opens perfectly in my 19.0 version. Try to open SpaceClaim or DM first and then import geometry.Â
March 16, 2018 at 11:34 am
Eric
SubscriberHello vganore,
thank you for your comment. Unfortunately this wasn't the solution for my problem. Spaceclaim opens my SolidWorks-file, but i can't save it. It seems to be to big. Can that be the problem? My model has less than 300 areas, but where can i check the number of bodies? Â
I have changed the language to English. Now its easier to talk about the error messages.
March 16, 2018 at 11:15 pm
peteroznewman
SubscriberHello Eric,
I am fortunate to have access to both SolidWorks 2017 and a full license for ANSYS.
If you would like to put your SolidWorks assembly into a zip file and attach that to a post reply below, I will open that file and see if I have any issues.
One way you can count faces and bodies is to duplicate the Geometry item, then open it in DesignModeler.
DesignModeler has a summary for a part.
March 17, 2018 at 1:00 pm
Eric
SubscriberHello,
luckiliy I could fix my problem. The solution was to prepare my files with the repair-tools in Spaceclaim. For some reason it looked like my files have to many bodies/surfaces. Now I am able to open it in Ansys (:
Thanks to all of you that helped me.
Eric
- The topic ‘Ansys doesn’t open my SolidWorks files’ is closed to new replies.
6625
1311
