November 21, 2018 at 8:02 am
lakshmi
SubscriberHi,
I was trying for internal fluid analysis in a 3D model using discovery live. I'm not able to go to 'solutions' section after inlet/outlet is selected. Is there anything that I should keep in mind while choosing inlet/outlet for enabling volume extraction correctly so that I can proceed with internal fluid analysis?
November 21, 2018 at 8:17 am
Naresh Patre
Ansys EmployeeHello lakshmidnair99,
It could be possible that there are additional openings in the model which you need to look at and close them.Â
You can also extract the internal fluid volume first using "Volume Extract" tool from Setup menu and then use this fluid volume for internal fluid flow analysis.
November 21, 2018 at 11:41 am
Keyur Kanade
Ansys EmployeePlease check following video. It may help you.Â
https://www.youtube.com/watch?v=1LBPLfs3QSo
November 21, 2018 at 3:51 pm
lakshmi
SubscriberHi,
thanks, could you please tell me the short cut key to have a cross sectional view of the 3D model (At 4:20 of the video above).
Many thanks
November 22, 2018 at 3:59 am
Keyur Kanade
Ansys EmployeeThe short key is 'x'.
- The topic ‘Ansys Discovery Live- volume extraction for Internal fluid analysis’ is closed to new replies.
5849
