July 2, 2021 at 12:22 pm
seghier
SubscriberHello
I use udp in python to send data from Rhino grasshopper to Ansys discovery live
Is there a better way to keep Ansys receive data without problem?
aAd is there a way to use Python instead of Ironpython?
July 12, 2021 at 2:43 pmRK
Ansys EmployeeHello Regarding exporting data from Rhino to Ansys, you will have to check the user manual of Rhino. And no, the python version what we are using is the only one that can be used.
July 12, 2021 at 4:00 pmseghier
SubscriberThanks RK
i used this to connect Ansys session to Rhino via python and i success to send command and control Ansys discovery live , i also use python to get some data from the connected session but some tools don't work like this
SpaceClaim.Api.V19.Unsupported.Live.Solution.GetAllSolutions
and i can't get some data like from calculator (chart)
SpaceClaim plugin for Rhino only available for Rhino 5, and i need to send data using the session connection feature, i send some commands with :
SpaceClaim.Api.V19.api.Command.Execute(command)
Viewing 2 reply threads- The topic ‘Ansys discovery live , python and udp’ is closed to new replies.
2968
970
857
599
591
