February 18, 2022 at 1:15 pm
jorge.vilhena
I get this messages when I am trying to follow the "Getting Started - Thermal" tutorial from the "Discovery community forum".
I followed exactly the same steps and I am stuck with this problem. I can run the solver but only for the fluid flow. Can anyone help me to overcome it?
Best regards,
Jorge
February 18, 2022 at 1:52 pm
subashni.satish
Forum ModeratorHello Jorge Vilhena
Which mode are you trying out your simulation in, the Refine mode or the Explore mode?
Also, which version of Discovery are you using?
February 18, 2022 at 4:46 pm
jorge.vilhena
SubscriberHi Subashni ,
I was in the explorer mode like in the tutorial.
I am using Release 2021 R2.
Jorge
February 21, 2022 at 7:13 am
subashni.satish
The Fluid Solid Heat transfer in Explore mode was introduced in the latest 2022 R1 version.
Please note that the tutorial sues 2022 R1 version as mentioned in the video title.
I would recommend you download the latest version from here to run Fluid solid heat transfer simulation in explore mode.
If you are using the older version, you can try the same simulation in Refine mode.
February 21, 2022 at 11:29 am
jorge.vilhena
SubscriberHello Subashni
In the meanwhile, I have tried the refine mode and it worked well.
Soon, I will update to the new version.
Thank you for your help.
Jorge
- The topic ‘Ansys discovery: “Fluid-solid heat transfer is not supported in this stage” warning message’ is closed to new replies.
