3D Design
3D Design
ANSYS DISCOVERY AIM RUNNING VERY SLOW
    • rohandixit1987
      I am performing Modal Analysis on ANSYS Discovery AIM Software. However, the software is running very very slow. I am unable to upload some heavy files (for example - Engine Block, Cylinder Head).
      Request to provide a solution for the same.
      RD
    • Brian Bueno
      RD
      Did you want to submit the files for us to investigate?  There's not much I can suggest without some further information.
      • rohandixit1987
        Brian Bueno Naresh Patre
        I am trying to open a .scdoc file whose size is 47MB in DISCOVERY AIM. The software is getting crashed all the time. However, I am able to open the file in LIVE and SPACECLAIM. I also did Modal Analysis in LIVE.
        Please can you clarify and suggest any solution.
      • Brian Bueno
        RD
        Are you able to submit the file for investigation?  It's difficult to give any suggestions without having a clear understanding of the problem.
        If the file is proprietary we can arrange another method to transfer it.
      • rohandixit1987
        Brian Bueno Hi, I cannot send the file to you. It's confidential data. Please send your person to TATA MOTORS, PUNE to solve the problem.
      • Naresh Patre
        RD Brian Bueno
        IT was observed that AIM was taking considerable time in opening a project, importing and editing a geometry part and also while saving. To overcome this issue, we first rebooted the machine, then cleared %temp% folder and also renamed v195 folder from %appdata%. These changes seemed to work and we could no longer see delays in the processes listed above.
  • The topic ‘ANSYS DISCOVERY AIM RUNNING VERY SLOW’ is closed to new replies.
