Ansys Products
Ansys Products
Ansys Discovery 2025 R2 – Missing Enterprise (disco_level3)
    • ajh31
      Product: Ansys Discovery 2025 R2
      License Type: Academic Campus License
      Description of Issue: We are experiencing a licensing issue with Ansys Discovery 2025 R2 related to Enterprise‑level functionality (disco_level3). When launching Ansys Discovery 2025 R2, users are presented with three license options:
      • Pro (disco_level1)
      • Premium (disco_level2)
      • Enterprise (disco_level3)
      Selecting Pro or Premium allows Discovery to launch successfully, though with limited functionality. However, selecting Enterprise results in the following error: “No feature exists. disco_level3” Our current license file includes disco_level1 and disco_level2, but does not include disco_level3. As a result, Enterprise‑level features such as extensive material libraries, porous filter flow definitions, and other advanced capabilities are unavailable in Discovery 2025. These same features are available to our users under Ansys Discovery 2024, but no longer function in the 2025 release.
      After contacting our Ansys representative, I was informed that enterprise‑level functionality should be included under our existing license and that the current license file, which does not list disco_level3, is correct. I was subsequently directed to the forums to inquire whether there is a technical reason or workaround for the observed licensing behavior.
      Thank you,
    • Rajeshwari Jadhav
      Can you please share the full name of license you have or else check if it's visible over here ProductToFeatureMap-2025-06-11.pdf
      Let me know if it shows disco_level3 as included for your license.
    • ajh31
      Thank you for your reply.
      We currently have Ansys Academic Multiphysics Campus Solution. I also do not have permissions to view that PDF.
      Any additional recommended steps?
    • Rajeshwari Jadhav
      Thanks for sharing the name of the license, this license only includes discovery pro (disco_level1) and premium (disco_level2) increaments.
      You can try using an alternate license which will allow you to use enterprise level functionality.
      Launch your Discovery application> File> Settings> License and have the below setting, make sure "Check for lower license if requested unavailable" is turned off (not in blue colour).
