Ansys Free Student Software
ANSYS “Could not make and SSL handshake with server” Read-only in every program – SOLVED
    • jcgodinho96
      It was working fine until i got this "handshake" errors, and could not do anything besides read-only mode on fluent. u've seen all tutorials and discussions, and nothing till now. please help
      Could not make an SSL handshake with server 51715@127.0.0.1.
      System error: 0 "".
      2019/11/24 06:08:15    INFO                Demo license file C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic exists.
      Could not make an SSL handshake with server 51536@127.0.0.1.
      System error: 0 "".
    • jcgodinho96
    • jcgodinho96
      license.err
      ANSYS installation: dom nov 24 05:037 2019
      Revision: 2019 R2
         ###### Error #######
         Could not find configuration script: AnsConfigACP.tcl
         Could not find configuration script: AnsConfigHelp.tcl
         Could not find configuration script: AnsConfigCHEMKIN.tcl
         Could not find configuration script: AnsConfigFORTE.tcl
         Could not find configuration script: win_fensapconfig.tcl
         Could not find configuration script: AnsConfigCAD.tcl
    • tsiriaks
      Close all ANSYS applications, then open CMD Prompt and issue the following command
      move "%appdata%ansys" "%appdata%ansys.old"
    • jcgodinho96
      hello! i actually already tried that and didnt worked. even installing new version of R3 or lower. but i already managed to open ansys normally.
      the solution: uninstall anti-virus and reinstall ansys.
      but thanks !!
    • tsiriaks
      Thank you for the update.
      Win
    • anrg23
      I have the same problem but even when I reinstalled ansys it didn't work can you pls help me out?.
Viewing 6 reply threads
  • The topic ‘ANSYS “Could not make and SSL handshake with server” Read-only in every program – SOLVED’ is closed to new replies.
