TAGGED: ansys-aqwa, aqwa-errors, hydrodynamic-diffraction
November 3, 2024 at 11:00 pm
as4934
SubscriberHello,
I am trying to simulate a sphere that is floating on the surface of the water. However, when I go to solve the simulation in the hydrodynamic diffraction module, I get the error: "LIDGEN:MAXIMUM NUMBER OF ELEMENTS EXCEEDEDDURING INTERNAL LID GENERATION." "LIDMES:FAILED TO CREATE INTERIOR LID FOR STRUCTURE#1 ; IT MAY BE NECESSARY TO USE SMALLER LID_SIZE." "READING DECK 2:EXTERNAL GROUP NUMBER 40 HAS NO VALID ELEMENTS." "MATERIAL GROUP# 98000 FOR STRUCTURE # 1 DOES NOT EXIST." "GEOMETRY GROUP# 98000 FOR STRUCTURE # 1 DOES NOT EXIST.". I have tried lid element size of 0.001 m through 5 m and none of them seem to work. I have also attached an image of the errors and the project files here. Any help is very appreciated. Thank you!
November 4, 2024 at 5:03 am
NVN NAMMA
SubscriberCould you please describe more on your model, where you are using the internal lid in your sphere?
November 4, 2024 at 9:29 pm
as4934
Subscriber-
November 5, 2024 at 5:08 am
NVN NAMMA
SubscriberSlice the geometry where it coincides with the water surface. An internal lid is not required. Model Cg accurately. Check hydrostatic values first.
5804
