October 30, 2024 at 3:40 pm
NVN NAMMA
SubscriberIn ANSYS AQWA: I had difficulty in modelling a flooded pipe. The actual volumetric displacement and equivalent volumetric displacement differed by 50%. Is it required to give the water weight by distributed mass?
November 3, 2024 at 7:30 am
NVN NAMMA
SubscriberÂ
I have modelled a long vertical pipe as a line body, which is free at the bottom and fixed to a floating structure at top. In the model tree it is modelled as floodable. Do I need to create an internal tank inside the flooded pipe . During the time domain simulations, it is floating on the surface. Â Kindly give assistance
This is the hydrostatic result.
November 4, 2024 at 10:13 am
Shuangxing Du
Ansys EmployeeThere is no need to use internal tank to define the water inside the floodable circular tube.
In your model, the equivalent volumetric dispalcement is the structure mass dividing the water density, which is 48e5/1025=4682 m^3.
It seems that the actual volumetric displacement result is questionable. Please check (your project)\dp0\AQW\Analysis\Analysis.dat, which should be similar toÂ
(1)Â in Data Category 2, TUBE elements instead of STUB elements (see 6.3. Element Topology Data Record)Â are defined.
(2) in Data Category 4, TUBE geometry's diameter, thickness and indicator of floodable (=1) are defined properly. (8.3. Geometric Property Data Record)
November 4, 2024 at 5:00 pm
NVN NAMMA
SubscriberThanks Shuangxing Du for attending my query.Â
(1) They are tube elementsÂ
That is also there. The disc element was not there initially, so I tried giving it a try to see if there were any changes. In the data file shared, there were two tube elements. I have only one tube element. is it reason for the change. The weight of the pipe is 4800 t, actual displacement is matching with the same. but the equivalent displacement is of volume displaced, which is different. Do I need to add a point mass corresponding to the difference in weight? The material of the pipe is not steel.
This is how my tube definition comes
when we click on the part line body
This is the problem.Â
November 4, 2024 at 5:52 pm
Shuangxing Du
Ansys EmployeeThe cross sectional area of the tube is A=pi/4*(10.5^2-10.0^2) = 8m^2. The length of the tube could be L=4800t/7.8/A=77m. The displaced volumn of the foodable tube should be about A*L=616m^3. Is the total displaced volume of 8050^3 mainly contributed by the floating structure?
November 4, 2024 at 5:56 pm
NVN NAMMA
SubscriberÂ
The length of the pipe is fixed as 1000 m
November 5, 2024 at 9:25 am
Shuangxing Du
Ansys EmployeeGreat. Please use the formulae I used to estimate the displaced volumn of the tube by hand.
