TAGGED: ansys-aqwa, ansysaqwa, aqwa, aqwa-errors, aqwa-suite
June 16, 2022 at 4:44 pm
javier.medina.galera
SubscriberI'm working on my master thesis with Ansys Aqwa about mooring analysis of spar platforms. I was having some issues when performing some calculations.
In particular, I'm trying to add some additional stiffness to roll, pitch and yaw motions to decrease/increase the natural periods of the platform I'm studying. I'm using the additional hydrostatic stiffness matrix option but it doesn't change anything in the dynamics of the platform for the rotational degrees of freedom. If, for instance, the natural period of yaw is 30 seconds and then I add an additional stiffness component for yaw, then the natural period would stay the same. The latter happens for roll and pitch motions. I have tried from really small values to huge ones but nothing happens.
By contrast, if I want to modify the surge, sway or heave natural periods, adding additional hydrostatic stiffness for those degrees of freedom does change the platform dynamics. To get the natural periods I perform a decay test with a time response analysis.
I don't know what is happening as changing the stiffness should modify the natural periods also for rotational motions. I'm aware that the hydrostatic stiffness of yaw is negligible but not for roll and pitch.
I would like to be able to increase the global stiffness for roll, pitch and yaw but I don't know how to do it. I can't change the mooring lines as they are a design condition. I was wondering if there is an option to increase the stiffness in those degrees of freedom that I could use.
Thank you very much -
June 22, 2022 at 8:01 am
Mike Pettit
Ansys EmployeeFor anyone else with the same question, please see the answer provided here: /forum/forums/topic/adding-stiffness-to-rotational-degrees-of-freedom/
Mike
- The topic ‘ANSYS AQWA – Adding additional stiffness to rotational degrees of freedom’ is closed to new replies.
