Ansys ACT – Scoping Method
    • lukaszd13
      Hi all
      Anyone knows how to change scoping method from geometry selection to named selection and then use a predefined geometry for result presentation?
      #Add total deformation
      dt = ExtAPI.DataModel.Project.Model.Analyses[0].Solution.AddTotalDeformation()
      dt.DisplayTime=Quantity("1.0 [sec]")
      dt.Name = "Global Deformation"
      dt.????? - to select only a part of the structure.
      Thanks in advance!
    • alexmarsh
      I've been struggling with a similar problem, but seem to have got somewhere. The values of dt.InternalObject.GeometryDefineBy should be different depending on whether you have geometry selection or (as in my case) a construction geometry surface selected - I assume something similar is true for a named selection. You can set this value by dt.InternalObject.GeometryDefineBy = the value corresponding to the scoping method you want. That's all I've got for now, hope it helps
    • alexmarsh
      An addition, in case anyone has a similar problem: I was missing the need to define dt.InternalObject.PathSelection = (ObjectId for the surface I had created)
  • The topic ‘Ansys ACT – Scoping Method’ is closed to new replies.
