December 10, 2024 at 8:56 pm
nickmiddleton22
SubscriberI am trying to use ansys ACP to model a delamination fracture. However, it is only possible to make the fracture laminae from a 2d plane. How do you make a frature in the mesh between the laminae when the geometry from which it is based on is 2d. I need to know how to model the complete delamination fracture with various fiber orientations. I have been unsuccessful in making a 3d simulation work on my own. Thank you for your assistance.
December 12, 2024 at 9:46 am
Ashish Khemka
Forum ModeratorHello,
Please see if the following posts are of any help to you:
how to create a crack on a 3D surface body in ANSYS workbench?
Cohesive Zone Model Delamination Solution Results
Ashish Khemka
December 12, 2024 at 4:01 pm
nickmiddleton22
SubscriberI need to make the crack along the same plane as the surface. If the surface is generated on the XY plane, How to I make the crack appear on the XY plane in the mesh component?
December 17, 2024 at 5:41 am
Ashish Khemka
5934
1306
