December 10, 2024 at 9:48 am
david.slaven
SubscriberOn behalf of one of our students, Bas
ically after i model my design and go to the results stage , this error arises and i couldn't move forward.It happened to lot of my colleagues. Ive asked for the file with the problems but not received it, would it help if I posted the file causing the error ? thanks Dave -
December 10, 2024 at 11:15 am
Forum ModeratorCan you run any of the tutorials? If you're using Fluent I'd also suggest not using Workbench and CFD Post. The workflow was changed a few years back to revert to Geometry>Fluent Meshing>Fluent with no need to go near WB.Â
December 10, 2024 at 3:11 pm
david.slaven
Subscriberthanks for the update, I have advised our customer
January 6, 2025 at 1:34 pm
January 6, 2025 at 2:08 pm
Forum ModeratorPlease can you repost the image?Â
January 6, 2025 at 2:15 pm
George Karnos
Ansys EmployeeAs we can not open files, please post the image of the error.
Also, under %TEMP%\ there will be directories:
\WorkbenchLogs
\WorkbenchjournalsIf you check the latest log file under WorkbenchLogs, does it list any errors?
Also, if you check the Windows System Event Viewer, does that list any errors?
5674
1890
1419
