May 14, 2020 at 8:22 am
May 18, 2020 at 10:50 pm
tsiriaks
Ansys EmployeeI've only seen this error 2-3 times.
Open CMD Prompt, then enter the following command
set
and post the output of it here.
July 9, 2020 at 7:01 pm
July 9, 2020 at 9:28 pm
tsiriaks
Ansys EmployeeWhat is the name of the installation package that you used ?
Try the followings:
1. Open CMD Prompt and enter the command
move "%appdata%ansys" "%appdata%ansys.old"
2. Change the value order of your PATH Environment Variable to make sure that
C:WINDOWSsystem32;C:WINDOWS;C:WINDOWSSystem32Wbem;…
entries are in front of everything else.
For example: PATH=C:WINDOWSsystem32;C:WINDOWS;C:WINDOWSSystem32Wbem;…all other entries...
3. Install all pending Windows update
If you still encounter an issue, post screenshot of the error.
July 10, 2020 at 4:26 am
Shahzad
SubscriberThanks for fast reply, Its ANSYS 2020R1. i tried the above method but still same error. I used this last month without any trouble, but suddenly opened a file after a week this happened. I reinstalled it also but still same error pop up while opening workbench, if you turn this off workbench will also be turned off. Please have look at this problem, i have to submit my work next week. It'd be appreciated if you spare some moment to help out.Â
July 10, 2020 at 11:32 pm
tsiriaks
Ansys EmployeeÂ
If it worked last month, you will need to see what software you installed this past month and what Windows updates were pushed and installed. You may have to uninstall or revert back.
As for the installation package, can you tell me the exact name of the file ? Where did you get this package from ?
December 9, 2020 at 5:51 am
tgleim
SubscriberI have a problem with Ansys 2020R2 and Centos 8.2.2004. I could install Ansys and received no problems, but i obtain an error when i start the workbench. I have installed all the necessary libraries. What is missing? The errornis in the attached log file.n -
December 9, 2020 at 12:00 pm
tgleim
SubscriberI have a problem with Ansys 2020R2 and Centos 8.2.2004. I could install Ansys and received no problems, but i obtain an error when i start the workbench. I have installed all the necessary libraries. What is missing? The rest of the text is in the attached log file.nnn[gleim@localhost Schreibtisch]$ cd ..n[gleim@localhost ~]$ ./Software/ansys_inc/v202/Framework/bin/Linux64/runwb2 nStacktrace:nn at<0xffffffff>n at (wrapper managed-to-native) Ansys.UI.Toolkit.QTC.Application.new_ans_qt_Application () [0x00002] in <95ee447321d04002b5da4f139e6b7785>:0n at Ansys.UI.Toolkit.QT.Application..ctor () [0x0000c] in <95ee447321d04002b5da4f139e6b7785>:0n at Ansys.UI.Toolkit.QT.UIFactory.newApplication () [0x00000] in <95ee447321d04002b5da4f139e6b7785>:0n at Ansys.UI.Toolkit.UIFactory.newApplication () [0x0000f] in <739c80a5535340d3a7cbe6d1a4647531>:0n at Ansys.UI.Toolkit.Application.InstantiateIApplication () [0x00000] in <739c80a5535340d3a7cbe6d1a4647531>:0n at Ansys.UI.Toolkit.Application..cctor () [0x0000a] in <739c80a5535340d3a7cbe6d1a4647531>:0n at (wrapper runtime-invoke) object.runtime_invoke_void (object,intptr,intptr,intptr) [0x0001e] in :0n at <0xffffffff> -
December 9, 2020 at 2:00 pm
tgleim
SubscriberI have a problem with Ansys 2020R2 and Centos 8.2.2004. I could install Ansys and received no problems, but i obtain an error when i start the workbench. I have installed all the necessary libraries. What is missing? The rest of the text is in the attached log file.nn[gleim@localhost Schreibtisch]$ cd ..n[gleim@localhost ~]$ ./Software/ansys_inc/v202/Framework/bin/Linux64/runwb2 nStacktrace:nn at<0xffffffff>n at (wrapper managed-to-native) Ansys.UI.Toolkit.QTC.Application.new_ans_qt_Application () [0x00002] in <95ee447321d04002b5da4f139e6b7785>:0n at Ansys.UI.Toolkit.QT.Application..ctor () [0x0000c] in <95ee447321d04002b5da4f139e6b7785>:0n at Ansys.UI.Toolkit.QT.UIFactory.newApplication () [0x00000] in <95ee447321d04002b5da4f139e6b7785>:0n at Ansys.UI.Toolkit.UIFactory.newApplication () [0x0000f] in <739c80a5535340d3a7cbe6d1a4647531>:0n at Ansys.UI.Toolkit.Application.InstantiateIApplication () [0x00000] in <739c80a5535340d3a7cbe6d1a4647531>:0n at Ansys.UI.Toolkit.Application..cctor () [0x0000a] in <739c80a5535340d3a7cbe6d1a4647531>:0n at (wrapper runtime-invoke) object.runtime_invoke_void (object,intptr,intptr,intptr) [0x0001e] in :0n at <0xffffffff>
- The topic ‘ANSYS 2020 R1 Workbench crashing due to Fatal error’ is closed to new replies.
4607
1510
1386
1209
