April 17, 2024 at 7:29 pm
gdickey2
SubscriberHello all,
I'm currently testing to figure out how I can analyze the maximum principal strain of 2 solid sets at a time using elout in the Binout option in Ls PrePost. Previously I have always analyzed 1 solid set at a time. For context, I am analyzing 2 separate chambers of the human heart in the TOYOTA THUMS model. I tried setting up a second solid set, but when I open the Binout --> elout --> strain --> solid , I don't see the solid sets separated to pick from, and I just see a big group of elements in the elout branch. Is there any way around this? What have I done wrong to not see the 2 solid sets separately?Â
Thank you in advance, Grant.
April 18, 2024 at 11:56 am
ytian
SubscriberI do not think elout would separate elements into different sets. I suggest you renumber the elements in the intended sets into different number ranges, for example elements in set A starting from 10k, and elements in set B, starting from 200k, - range depending on how many elements you have in the sets.
April 19, 2024 at 1:25 am
Reno Genest
Ansys Employee-
April 19, 2024 at 2:53 pm
gdickey2
SubscriberHello Reno,
Thanks for this. The problem I have is that the model I'm using, the elements are not ordered in a sequential pattern. That is, they jump numbers (e.g., 1470089, 1470112, etc.). I played around quite a bit to see if I could sort this, but there are thousands (~4000) in each set. It's likely faster for me to just run 2 separate simulations with the separate sets. Unless there is something else I can do that could potentially deal with this problem.
Thank you,
Grant
April 19, 2024 at 9:44 pm
Reno Genest
Ansys EmployeeHello Grant,
Let me check with a developer and get back to you.
Reno.
April 20, 2024 at 2:29 pm
gdickey2
SubscriberThank you Reno, I look forward to hearing back from you.
- Grant.
April 23, 2024 at 2:47 pm
Reno Genest
This feature is not available yet, but we now have an enhancement request to implement viewing elout results for each *SET_SOLID.
Reno.
April 23, 2024 at 3:45 pm
gdickey2
SubscriberThank you Reno, will I be notified when the enhancement request has been fulfilled? Will this be in the form of an updated version of Ls-PrePost?
Thank you,
Grant
April 23, 2024 at 3:54 pm
Reno Genest
It may take some time for this enhancement request to be implemented based on priorities. If it is implemented, it will be in the DEV version of LSPP that you can download here:
For now, your best option is to renumber the elements in LSPP and search FromID:ToID for elout results.
Reno.
May 22, 2024 at 3:54 pm
Reno Genest
The developer implemented this feature in the latest LSPP4.12 after 5/21/2024. You will be able to download it here when available:
https://ftp.lstc.com/anonymous/outgoing/lsprepost/dev/
It is not available yet, but it should be in a few days.
Reno.
- The topic ‘Analyzing elout for 2 solid sets in Binout’ is closed to new replies.
6795
1333
1152
