LS Dyna
LS Dyna
Analysis Theory in LS-DYNA
    • 広典 小松
      Hello.
      Where can I find information about the formulas used in the DEM (Discrete Element Method), explicit method, and implicit method used in LS-DYNA?
      If you look at the LS-DYNA_Manual_Theory_R14 that was in the file when you installed LS-DYNA, is it all written?
      We look forward to hearing from you.
    • Ushnish Basu
      The theory manual has the governing equations for explicit and implicit analysis. For DEM, do a google search for "ls dyna dem", which will give you links to pdf presentations on DEM, and these have the references that you can look up for the theory.
  • The topic ‘Analysis Theory in LS-DYNA’ is closed to new replies.
