April 12, 2024 at 4:11 pm
April 15, 2024 at 4:47 pm
Chris Quan
Ansys EmployeeCan you explain how this error message was encountered?
This error message indicates that the model setup in Autodyn Component system has not been completed. There are some setup that are missing in the Autodyn Component system.Â
Are you able to run the model in Explicit Dynamics system for a short period of time as a test to make sure the model has been setup correctly?
If the model runs in Explicit Dynamics system, are you able to open the Autodyn model in Autodyn Compoenent system? If not, can you delete this system and drop & drop a new Autodyn Component system to the Setup cell of Explicit Dynamics system? Finally, right click on Setup cell of Autodyn Compoenent system and then click on Update to update Autodyn system. Autodyn GUI will start automatically.Â
If the model can be opened in Autodyn system, try running it to see what new error messages are.
- The topic ‘Analysis component failed in Autodyn failed run Error’ is closed to new replies.
